redstormcoach's Avatar
How do you mask of Fuchs when painting?
I am in the process of redoing my Fuchs. I have taken off all the paint and polished the lip and lightly sanded the pedals to get them ready for paint. My question is, what is the best method for masking off the lip and making it a perfect, straight lined circle?
Thanks.
Old 02-01-2009, 05:21 PM
efhughes3's Avatar
I've used blue painter's masking tape and electrical tape-both with sharp-lined results. Masking tape just takes longer to work around the curves.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-01-2009, 05:26 PM
Nevermind. I did a search and found the answer. I don't know why I asked first before searching.
Old 02-01-2009, 05:28 PM
Band.
If you're doing an all-black center, I had good results by "over-taping", completely cover your polished lips and tape just into the part that will be black. Then take an EXACTO-knife and cut along the edge of where the black will be. There's a little ridge there and it's pretty easy. Then remove the tape in the center and you have a really nice line.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 02-01-2009, 05:47 PM
Senior Advisor
James Brown's Avatar
don't worry about masking, just spray it and clean it up with solvent using your finger to keep a sharp edge. works great, no masking, and just use a can of flat black paint. it will last 5 years easy to re-due.
3 years old and still looking good. cost $ 10.00
08 Cayenne Turbo
Old 02-02-2009, 01:47 AM
Noel's Avatar
2nd electrical tape near the spokes, then use painters tape and newpaper to cover the tires. I did this about 5 years ago and they turned out great.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 02-03-2009, 06:11 PM
175K911's Avatar
I've used automotive pinstripe tape for the exposed edge, with blue painters tape for the rest of the masking. Pinstripe tape is very flexible and leaves a clean edge. And being much narrower than electrical tape means it's easier to make the arc necessary to mask off the area. But electrical tape is less expensive.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 02-04-2009, 05:37 AM
Fritz Peyerl's Avatar
masking rims
this subject just came up on the 912 BB and they had a link to a easy way to paint your rims.
http://www.themotoringjournal.com/cars-for-sale/refinishing-fuchs-at-home.html
Fritz
Old 02-04-2009, 09:01 AM
