Fan on a 28 tube brass oil cooler?
I came across a 6.5" Spal pusher fan and was wondering if anyone has tried this(or similar) on a 28 tube brass oil cooler? Temps currently are fine but if someone have seen any benefit to this addition, it might be worth trying. Thanks.
Old 09-04-2005, 11:55 AM
a fan always helps.
206 637 4071
Old 09-04-2005, 11:59 AM
Thanks J.W. Would it matter which side of the cooler to mount the fan?
Old 09-04-2005, 12:17 PM
front if it's a pusher. not much room in the rear.
206 637 4071
Old 09-04-2005, 12:23 PM
North Coast Cab's Avatar
I did it. It helps when idling or moving slowely, but at full speed it does nothing.
John
1985.5 944 GTS
Old 09-04-2005, 04:38 PM
Thanks John. How did you end up attaching the fan to the cooler?
Old 09-05-2005, 07:42 AM
long and thick zip ties will work well on the tube unit.
206 637 4071
Old 09-05-2005, 08:01 AM
I have plenty of those. Should be easy to do. Thanks, J.W.
Old 09-05-2005, 08:07 AM
I used zip ties on my 7.5" Spal. Additionally, I ducted the bottom of the oil cooler to improve air flow effeciency, also used zip ties to secure duct and insure that I can remove it easily if needed.
Alan
1988 924 S
500 in US
Black (the only color)
82 SC Guards Red/Black . (Sold)
SSI's, No Cat, Bursch, H4's plus relays/wiring upgrade
Old 09-05-2005, 09:54 AM
Crotchety Old Bastard
RarlyL8's Avatar
I've never seen a cooler that looked like yours Alan. 28 row units are tubes only. What's the story behind it?
Old 09-05-2005, 11:58 AM
Thanks Alan. I have never seen an oil cooler like that either. What kind is it and did you see much difference with the duct work? It looks like a good idea. Thanks for the photos. Do you use a manual switch to activate the fan?
Old 09-05-2005, 02:29 PM
John
Is it pushing or pulling?
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 03-06-2008, 09:01 AM
