I'm a loser, baby.
oregonmon's Avatar
Would a 3" diameter inlet/outlet muffler work on a SC?
Saw a guy selling two Dynomax Ultraflow Welded SS mufflers that are a straight through design for a good price but they are 4" diameter and 3" inlet/outlet. Total length is 23".
Would something like that work. Actually just thinking about a cat bypass and sport muffler for now for a low budget mod.
Please don't recommend the SSI's, because I know they are a great upgrade, they are so expens
1979 911 SC
Old 03-13-2008, 02:01 PM
Capitalist and Patriot
911Freak's Avatar
What kind of setup are you considering attching these to? Stock H/Exchangers?
I'm sure other more knowledgable guys will chime in on this but isn't the ID of these poss. to big, and thus hurt performance?
FWIW I run, for now, stock H/Ex with a Cat by-pass, thru a 1 in 1 out B&B Muffler with a giant 4.5" tip... very happy with the performance gain and the tone..
But as soon as do my 3.0 to 3.2 rebuild I plan on running a set of Euro Headers with custom fab'd twin high flow Cats and a 2 in 2 out muffler...Incl as per Steve's suggestion: cross over pipe as I will come no where near 8000+ rpm's....
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 03-13-2008, 02:28 PM
I'm a loser, baby.
oregonmon's Avatar
Thinking a little outside the box, I know it's dangerous. But what about this. Have a exhaust shop fabricate piping coming off the driver's side heat exchanger and the crossover pipe (remove the cat) and run the two mufflers side by side in the space where the cat would go and a some pipe and two muffler tips exiting? Did I make that clear?
Enough room? No smog testing here by the way.
1979 911 SC
Old 03-13-2008, 02:29 PM
I'm a loser, baby.
oregonmon's Avatar
For now staying with factory HE's.
1979 911 SC
Old 03-13-2008, 02:32 PM
I'm a loser, baby.
oregonmon's Avatar
So I've stumped you guys?!
1979 911 SC
Old 03-13-2008, 09:20 PM
HarryD's Avatar
Ryan,
If I am not mistaken too lagre diameter will kill your bottom end by effectively reducing the scavenings effect.
I think there may be some threads here on exhaust system design. It would pay to take a look. Several have pointed out that it is difficult to improve the factory design, most settle for no lost perfomance in the quest for sound and looks.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-13-2008, 09:35 PM
3.2 CAB's Avatar
You could have pipes as big as garbage cans, if you have the engine set-up and adjusted for that. Those 1000+HP AA dragsters have short open pipes, but they are designed to be that way. It does not seem to me that you could not adjust some for the difference in back pressures. Just a thought.
I have test run my engine with just the cat, and it did not sound as obnoxious some of the ricers and their fart pipes. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-14-2008, 06:41 AM
That would be as loud as a cat delete with a muffler delete. I ran a 2 1/4 glass pack with a cat and it sounded great and ran great too. Then i switched out the cat for a euro pre muffler and the glass pack was way too loud because of the totally straight through design. Iv switchd out the cat for a modified muffler and it sounds much better but i think i may tear into again for a little bit more flow and sound eventualy. Building a custom exhaust for a porsche is very tricky and its easy to not get what you want. I can tell you i doubt youll like that setup
Old 03-14-2008, 06:49 AM
