50 rpm idle hunt on 78SC 3.0L
I just put new intake boots on my 78 SC to correct an air leak. Set the mixture without an analyzer using techniques on this site. Might be slightly rich but runs nice and cool and even through all RPMs under a heavy pedal. Good power and acceleration with no hesitation, hiccups, grumbling or back firing. Idle set at 950-975. However, after warm up, I get a 50 rpm idle hunt.
What might cause that?
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
Member 911 Anonymous
As you wrote, it may be a but rich, try leaning her out a tad see if that will clear up the minor hunt???
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Reiver
Rich mixture can do that...lean it a tad until it stops hunting but the idle does not increase in rpm.
De Oppresso Liber Strength and Honor 5th Legion |
Thanks. I did try that but it started to hesitate at 4-5000 rpm with a heavy pedal, so I went back to a tad richer and the hesitation went away. It doesn't bother me since I don't sit at idle much but it is not correct. The car was not designed to hunt like that.
RETIRED
Still sounds like a leak. You need an analyzer AFTER hunting down leaks. Propane or ether spray....listen for rpm changes.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I will try just a tiny leaning and see what happens.
Eva
thats your best bet
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Seeking
Years ago, I was taught to enrichen until the engine starts to seek an idle, then lean it back until you're smooth, then adjust the air on the TB for idle speed.
Bruce |
Reiver
A water mister spray works fine too...drops the rpm when there is a leak and you can't blow anything up.
hmm
I would think vacuum leak as well. on the wide side maybe breather leak. cheers, Geoff
Leaned it a hair and now have a 25 rpm hunt. Gonna lean it one more hair. Will report back.
Down to an intermittent 10 rpm hunt once in a while. Gonna lean her one more smidge. I don't think I have any significant air leaks -- plenty of room to adjust idle as needed.
Eva
10rpm hunt...on a 37 year old CIS car. You're dialed in just right.
83 SC
Subscribe
I did not do the final lean. Instead, I put some fresh gas and a dollup of Marval Mystery Oil in and ran it up to red line a few times. No hunt at all now, rock steady at 950 rpm. I am putting a fork in it and calling it done. Thanks for all the advice.
Brad
Here she is with a fresh Brazilian Wax Job.
NICE!
A bit OCD, eh? Well, I think we all are :-) for our babies. Yeap an Eyetalion Tune Up once in while is a good thing :-) Congrats Brother, Jim
