brads911sc's Avatar
Backdated Oil Line Question
I am in the final stages of Installing SSI's.. I did the oil lines today. I used anti-seize on threads going into thermostat and engine. Did nothing at place where two lines connect. Am I to use NO sealer? Just get the lines tight with the Anti-seize? This is an 83 SC that didnt leak a Drop of oil prior to the upgrade... and Id like to keep it that way... Thanks
Old 03-09-2008, 03:50 PM
Bill Verburg's Avatar
The hydraulic seal is from the ground joints, nothing else is needed. By all means use anti-seize on the threads
Bill Verburg
Old 03-09-2008, 04:09 PM
brads911sc's Avatar
Thanks Bill... Appreciate the info... Its what I suspected but always like to know what others do and get confirmation...
Brad
Old 03-09-2008, 04:21 PM
