Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Different Types of available rear flares for the 911?
What are the different rear flare types for the longhood 911?
Stock
SC
Turbo
RS?
RSR? (Those have a slightly different profile than the turbo, yea?)
Anything I'm missing?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 11-13-2019, 04:08 PM
Yeah the best ones ST
78 911 st backdate
87 944
00 996
Old 11-13-2019, 04:19 PM
Bill Douglas's Avatar
Yep, I also think ST are the most aesthetically compatible with the early 911 shape.
Old 11-13-2019, 04:27 PM
Rennch on YouTube
rennch's Avatar
Are ST flares available? What's their size compared to RSR or SC?
Michael O'Neal -
Old 11-13-2019, 04:47 PM
LOL, I'm just one of those guys who like looking at 911 pic's on the internet.
Old 11-13-2019, 05:15 PM
FrenchToast's Avatar
Probably a hundred of them. In addition to those mentioned,
No flare
M505 / SE / slats
Carrera flare with slats (Special Wishes / Exclusive)
Turbo RSR
RSR 2.8
RSR 3.0
RSR Iroc
934
934.5
964 Turbo S
964 RSR
993
993 with scoop (Exclusive)
993 Turbo
993 Turbo S
993 GT2
993 RSR
And, if they qualify..
935 (half a dozen variants)
959
965
If you include aftermarket; many, many more.
Old 11-13-2019, 05:55 PM
Rennch on YouTube
rennch's Avatar
Yowza. That's quite an extensive list. I should have clarified..."longhood" 911.
No flare
M505 / SE / slats
Turbo RSR
RSR 2.8
RSR 3.0
RSR Iroc
934
934.5
964 Turbo S
964 RSR
993
993 Turbo
993 Turbo S
993 GT2
993 RSR
959
965
Michael O'Neal -
Old 11-13-2019, 06:16 PM
Flojo's Avatar
regarding "stock" in term s of G-body there is only:
- the "narrowbody" up to mid 77
- SC/Carrera from 78 to 88
- and the turbo-flares.
missing ST from 71/72
RS?
RS is different in the vertical lip than SC/Carrera
RSR is way wider that even a turbo
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-14-2019, 02:07 AM
Bill Verburg's Avatar
The flares used on Carrera from 'sometime in '74 or '75 up are the same, the '73 RS through at least some of the early '74 Carreras had a subtly different shape. There is a thread from years ago w/ all sorts of pictures. I know for a fact that my '76 Carrera flares are identical to those through '89 911
from '64 not counting race and rally cars there have been only 4 basic fender sizes
shorter w/b
'64-68 6/6 wheels these cars came w/ almost slab sides and used 6" max wheel width
longer w/b
'69- 77 regular 6/6 wheels these cars have a bit more flare but still the same 6" max wheel widths oe though 7/7 could be fitted, These are often called 7" fenders
'73-74 Carrera 6/7 wheels w/ 7/8 options, these have a 2" wider rear fender than above and can be fitted w/ up to 9" wheels in back, fronts are the same 7" flares as above rear would be 9" flares
'75-89 SC & Carrera, 6/7 wheels, 7/8 option, these have the same fenders as above, the contour of the rears was subtly different in '73-74 but all accommodate the same 7 & 9" wheels
'75 -89 930 7/8 & 7& 9 wheels, these have the very wide fenders similar to those seen on the '73 RSR, the RSR used 9 & 11" wheels, so the flared are called 9" front and 11" rear.
ST used 9" front and 10" rear flares, the fronts were the same as were used on 2.8RSR the rears split the difference between 2.7RS and 2.8RSR
3.0RSR had 2" added to both front and rear 2.8RSR flared to accommodate 10.5" & 14" wheels
Bill Verburg
Old 11-14-2019, 11:22 AM
