Diesel_mp5's Avatar
Another Weber Question!
HI.. I have a 2.0 with Solex cams (that I love). But I am having difficulty setting up the Webers.
The car fires right up cold, it does hesitate when its warm. But it Idles smooth, accelerates fast, plugs look ok. But When I am cruising down the road it has a serious case of the pops. If I press on the peddle lightly it smooths right out until I let up on the peddle lightly to a steady speed and the popping starts again. But if I let up all the way it smooths out.
Is this the Main jet problem? To small?
Here is my setup Any help would be greatly appreciated.
Early 2.0 Sandcast case
Solex Centerlube cams
Webers 40 40IDTP13C1, the tapped holes on manifolds are plugged off. I dont have insulators yet but know I need them. K&N watershield
Mains 110
Idle 50
air correction 170
permatune 3 wire and a 70 coil SS Jacketed wires
2000 ft. elevation Las Vegas!
Humidity: 14%
Pressure: 30.14 in.
Dew Point: 10°F
66 912---- Putting the Six-in-it
79 911Sc Targa~~~ Sold
Old 03-07-2008, 07:57 PM
FPB111's Avatar
You do not say what RPM this happens at. If below ~3000 you are still mostly on the idle jets. Did you balance the carbs? Check out the PMO setup instructions. Most of what they have here
http://www.pmocarb.com/installation.htm
will be applicable to the webbers. Check the balance section.
Old 03-08-2008, 07:30 PM
Diesel_mp5's Avatar
Thanks for the reply, yha I have adjusted them quite a few times. But I will do that agin. And it really happens at any RPM under a sustained throttle level.
Old 03-08-2008, 08:02 PM
i'm just a cook
onlycafe's Avatar
check idle jets for obstruction. also as fpb said, check if carbs are synched.
Old 03-08-2008, 09:27 PM
1-6-2-4-3-5-1-6-2-4-3-...
pope's Avatar
Nice guide to tune your Webers, if you haven't seen it already:
Weber rebuild
'70 911E Coupe, Webers 40IDA
Old 03-09-2008, 12:30 AM
911Rich's Avatar
How is the rest of the fuel system? Fuel filter? Is the tank clean? debris/rust can lodge itself in the jets creating your condition. Also are you positive is is fuel and not ignition/wiring related?
Rich @ ROCS
Old 03-09-2008, 08:22 AM
