thrown_hammer's Avatar
Exclamation retractable seatbelt help!
I was reassembling the car last night. The driver side seatbelt won't release! It's stuck in the lock up posistion. I can feed belt in but it won't release. Is there a release tab or anything? It is almost all wound up on the spool, since I laid it in the front seat it reeled itself in. What to do?
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 04-17-2003, 04:07 AM
Siena911's Avatar
Shawn,
Try turning it right side up and it should release etc... give it a gentle shake.
Cheers Jakes
ps Nice progress on the car etc etc
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Old 04-17-2003, 04:11 AM
What?
trj911's Avatar
I agree w/ Jake, keep it right side up and if it can work, it will. If you want to try and take it apart, be very careful. One side is the spring and one side is the locking mechanism. If I remember correctly, the skinny plastic side is the spring, do not open that side. I learned this the hard way...BOING!!! Are you headed to ODaniels Sat? If I get a rain out on my son's baseball game I'll be there. I look forward to seeing the car and all your hard work!
TJ
Tom J.
911SC Cab
SCWDP
CaymanS
Old 04-17-2003, 05:37 AM
TJ,
The plan is to drive her to O'Daniels.(hope I don't get a seatbelt ticket) If not I will still be there in a friends 928.
1975 911S (sold)
Old 04-17-2003, 05:40 AM
85eurocarrera's Avatar
I have the same problem. the belt is wound up with about 24" left out. It is removed from the car. Any other suggestions other than shaking and pulling on it cause that aint working.
Thanks,
Joe
Nevermind. I think I got it.
Old 03-09-2008, 11:45 AM
Bob S's Avatar
If the belts are not installed, I suggest you bolt them on. These belts are made to release when installed at the at the proper angle. They can be opened if stuck by removing the side plastic cover. . If I remember correctly do not remove the cover on the flat side. That's where the spring is... Once inside you'll see how to release the belt. They do not have release tabs.. Hope this helps.
Bob S
1984 930S Silver
1996 993 Polar Silver (Sold)
1987 911 Guards Red ( Gone but not forgotten)
Old 03-09-2008, 12:03 PM
911 user...
Bob's got it. If you don't want to install them in the car, place the belt against a wall right side up as if it was mounted in the car. Be gentle and pull straight up on the belt; is should come out...
-Will
911SC & Audi S4
Count those blessings every night!
Old 03-09-2008, 01:03 PM
Thanks guys, figured out.
Old 03-09-2008, 03:19 PM
Throw it on the ground!
Great timing.....I had the exact problem yesterday. Unfortunately before reading here, we popped off the plastic cover releasing the spring!
Will be ordering a replacement. Based on this post, this problem seems common.....what specifically did you do to "figure it out"?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 03-10-2008, 03:51 AM
Thanks!
What Bob S said. I just bolted it back in place and worked it back out.
Old 03-10-2008, 05:37 AM
Doh!
Old 03-10-2008, 07:41 AM
