'Till death do they part?
My crossover/catalytic converter, can they be separated?
'84 911, some sort of red color '05 Subaru WRX wagon |
Friend of Warren
Mine looked that bad. Cut the nuts off and they separated easily. Course cutting the nuts off was a *****.
Kurt V No more Porsches, but a revolving number of motorcycles. |
What Kurt said, but he's sugar coating it
Blue Wrench (oxy-acetylene) will burn those nuts / bolts off in no time ....
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
torch/BFH.
Burn baby, burn... You might try an air chisel. You're not going to reuse the hardware anyway so you might as well get the hardware off as easily as possible without damaging any of the goods.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
RETIRED
Torch or dremel.......
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
If you can get a socket on them they will probrobly just snap off
82 SC , 72 914 |
oxy-mapp home torch kit. just did the nuts holding the O2 sensor on my 4Runner. was actually a lot of fun.
Tru6 Restoration & Design |
Skunk works
+1 on the gas-axe
964 RS-4 |
about three feet of det cord .. fix ya right up... I'm being a smart ass... use the heat
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
Dremel with cutting disc will take about 5 minutes to take them all off.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
2nd for oxy-mapp
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Where's the optimism...WD-40 and a box end wrench...no problem. =)
(Secretly I agree with all the others) It will come off one way or another. Good luck, Cooper
Cooper's Classy Car Care Providing Clear Bra installation, Paint touch-up, Detailing PCA/OCR since 1997 '81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter |
Alii&Maui
Air chisel
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
MBruns for President
Just soak for a few days with PB blaster ....
just kidding cut em off with a dremel - or better yet - take to a muffler shop - have em hike your car in the air - have a set of bolts you can stick on there for the ride home and have them cut em with a torch while you sip a fresca.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Those lower valve cover nuts (or am I disoriented?) don't look much better BTW ... I'd bet it's been a while since the last valve adjustment ...
The PO apparently wasn't much of a "car guy." Went to adjust the E-brake, which currently consists of a very weak brake and 1st gear, and the little adjuster you access through the hole wouldn't move. OK, so let's take the disk off and try some more persuasion... Discovered the cause of the slight shudder in the brakes, driver's side caliper outboard seal cracked and piston barely moves. Plus the little screws that hold the rear disk on are ON there, gotta get it to a place with an impact wrench. Let's order some remanufactured calipers while we're at it, oh hell, let's just go for the whole shibang. The up side is when I'm done with this thing, it'll be good to go for quite a long time. Still love driving it though.
what kind of super dremel do you have there? the last dremel i had took forever to deal with anything bigger than a nail.
