Automahn
Guest
Posts: n/a
Post how do you check for a shorted cell in the battery??
OK still have the battery light comin on in my car I have had the alternator out several times had it rebuilt and tested and have also put in a new regulator and fan belt and the lights still stayin on. I have read here it could be a shorted cell in the battery how would I check for that. My last ditch effort before I have to take my car to my wrench any imput would be appreciated.
Old 04-27-2001, 06:41 AM
john walker's workshop
Guest
Posts: n/a
Post
from porsche tech bulletin: if light does not go out, exciter current is too weak because of 2W lamp. in this case, resister 911 641 981 00/91 ohms, 5W, must be installed parallel to battery charge indicator lamp. ( between the 2 terminals on the lamp socket). 82 on should have a 4W bulb. is there a ground strap from the alternator housing to the engine case? usually a load test will show whether a battery is good, along with a hydrometer reading. on a fully charged battery, 15 seconds @ 150A load, the battery should not go below 10.5V. the hydrometer will show any dead cells.
[This message has been edited by john walker's workshop (edited 04-27-2001).]
Old 04-27-2001, 07:50 AM
ClayMcguill
Guest
Posts: n/a
Question
Umm...wouldn't it be easier to take the battery down to the local Wal-mart (or wherever) and have them load-test it?
Old 04-27-2001, 01:04 PM
