'Till death do they part?
My crossover/catalytic converter, can they be separated?
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 02-28-2008, 11:53 AM
Friend of Warren
Mine looked that bad. Cut the nuts off and they separated easily. Course cutting the nuts off was a *****.
Kurt V
Old 02-28-2008, 11:59 AM
What Kurt said, but he's sugar coating it . Mine were a PITA to get off too.
Old 02-28-2008, 02:16 PM
burgermeister's Avatar
Blue Wrench (oxy-acetylene) will burn those nuts / bolts off in no time ....
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-28-2008, 02:19 PM
torch/BFH.
206 637 4071
Old 02-28-2008, 02:43 PM
Mitch Leland's Avatar
Burn baby, burn... You might try an air chisel. You're not going to reuse the hardware anyway so you might as well get the hardware off as easily as possible without damaging any of the goods.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 02-28-2008, 03:05 PM
RETIRED
Joe Bob's Avatar
Torch or dremel.......
2012 ML350 3.0 Turbo Diesel
Old 02-28-2008, 03:23 PM
If you can get a socket on them they will probrobly just snap off
Old 02-28-2008, 03:36 PM
Shaun @ Tru6's Avatar
oxy-mapp home torch kit. just did the nuts holding the O2 sensor on my 4Runner. was actually a lot of fun.
Tru6 Restoration & Design
Old 02-28-2008, 04:00 PM
Skunk works
JV911SYDNEY's Avatar
+1 on the gas-axe
964 RS-4
Old 02-28-2008, 04:32 PM
about three feet of det cord .. fix ya right up... I'm being a smart ass... use the heat
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 02-28-2008, 05:50 PM
Dremel with cutting disc will take about 5 minutes to take them all off.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 02-28-2008, 06:30 PM
khamul02's Avatar
2nd for oxy-mapp
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-28-2008, 08:03 PM
Cooper911SC's Avatar
Where's the optimism...WD-40 and a box end wrench...no problem. =)
(Secretly I agree with all the others)
It will come off one way or another.
Good luck, Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 02-28-2008, 08:08 PM
Alii&Maui
Jesset100's Avatar
Air chisel
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 02-29-2008, 09:04 AM
MBruns for President
JeremyD's Avatar
Just soak for a few days with PB blaster ....
just kidding cut em off with a dremel - or better yet - take to a muffler shop - have em hike your car in the air - have a set of bolts you can stick on there for the ride home and have them cut em with a torch while you sip a fresca.
Old 02-29-2008, 09:21 AM
Those lower valve cover nuts (or am I disoriented?) don't look much better BTW ... I'd bet it's been a while since the last valve adjustment ...
Old 02-29-2008, 10:08 AM
Yeah, I was thinking the same thing, but I'm moving in baby steps on the maintenance. Shifter bushings a few days ago, probably original. Just changed the transmission and engine fluids. Brakes are next (see below) then a valve adjustment.
The PO apparently wasn't much of a "car guy."
Went to adjust the E-brake, which currently consists of a very weak brake and 1st gear, and the little adjuster you access through the hole wouldn't move. OK, so let's take the disk off and try some more persuasion...
Discovered the cause of the slight shudder in the brakes, driver's side caliper outboard seal cracked and piston barely moves. Plus the little screws that hold the rear disk on are ON there, gotta get it to a place with an impact wrench. Let's order some remanufactured calipers while we're at it, oh hell, let's just go for the whole shibang.
The up side is when I'm done with this thing, it'll be good to go for quite a long time.
Still love driving it though.
Old 02-29-2008, 10:51 AM
Good spot and spot on...
Old 02-29-2008, 10:55 AM
what kind of super dremel do you have there? the last dremel i had took forever to deal with anything bigger than a nail.
206 637 4071
Old 02-29-2008, 10:59 AM
