-   -   Targa Top Gurus (Gutter Question) (http://forums.pelicanparts.com/porsche-911-technical-forum/397539-targa-top-gurus-gutter-question.html)
vizail 03-10-2008 11:57 AM
Hi again
I'm recovering my Targa's Top and found that some of the finnishing of the gutter was peeling off I deside to strip off the entire gutter's. Then I began searching for something similar in the market with no luck so far. The factory finnishing is a thick film .
Have you been in the same situation? Let me know how you solve it.
PiX
http://forums.pelicanparts.com/uploa...1205175427.jpg
Cordially
VicSmileWavy
robinnz 03-10-2008 12:08 PM
I am just refurbishing my roll bar and "gutters" I will have them bead blasted then two pot painted to match the door handles and window frames - sort of a satin black
tcar 03-10-2008 12:48 PM
Sand them and paint w/ Rust-oleum Satin Black 9999.
vizail 03-10-2008 01:27 PM
I just wonder
Does DUPLY-COLOR Engine enamel will work?
VicSmileWavy
Skip Newsom 03-10-2008 06:39 PM
I had mine powder coated a gloss black, not original but it looks terrific and will be durable.
911Freak 03-10-2008 06:47 PM
All excellent advice....
I have the same issue with my Targa Top, and even though the outer skin is good, the seals need to be replaced, and b/c the paint is chipping off in huge chunks on the rain gutters, I'll be refinishing then before installing the seals...
Prep-etch prime-good quality single stage Black semi-gloss...
mossguy 03-10-2008 08:05 PM
Vic -I covered mine many years ago with shiny electrical tape. It has stayed on and still looks good. Quick and easy. If you don't like the look, easy to remove and do something else. (No disassembly of top required).
Tom
Allen_70S 03-11-2008 04:32 AM
A couple of years ago I had mine powdercoated (for durability) during rebuild of the targa top. I remember it being roughly $50 for both sides.
Al
Mysterytrain 03-11-2008 06:29 AM
I wonder if that rubberized crap you dip your tool handles in would work?
Mysterytrain 03-11-2008 01:14 PM
this stuff...
http://www.caswellplating.com/aids/plastidip.html
T77911S 03-12-2008 04:28 AM
what about wurths? i was planning on doing mine with it. as for flat black, the rest of my frame has a gloss to it and looks( or looked) very good. i had my top rebuilt and the guy that did it touched up a few nicks i had(even after i told him i did not what that done) with flat black walmart looking paint. i was not happy.
