Low Oil Pressure 78SC
Fellow PelicanHeads,
After searching the BBS, I have NOT found a thread about the down side of low oil pressure. I have been told that bearing wear causes low oil pressure. I have a race this weekend and would like for someone to explain the risk of low oil pressure due to bearing wear. TYIA, Craig
Stopped racing and became a drummer |
Max Sluiter
Could be a dislodged piston squirter if the oil pressure dropped suddenly.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Well, the oil suction tube is very loose. The only thing holding it in position is the screen.
Max Sluiter
How low is the oil pressure? Is it far below 10psi/1000rpm?
Do you have the cam housing oil feed line restrictors?
At the track last weekend, the oil pressure was normal during warm-up. Once on the track, the oil pressure was between 3 and 4 bar. Revving the engine, on the track, would not put the pressure at 4.4 bar like it normally does. Coming into the pits, it was 0.5 bar at idle and would only get to 3 bar at 6000 rpm.
Last weekend was for fun at the track. This weekend is a PCA club race and I'm worried that the race might grenade my engine.
Air Medal or two
maybe do some simple stuff 1 first ?? check your relief valves .??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
