Indebted user
Sam 69 Gulf's Avatar
Idle adj / mid range hesitation issues – Webers? (Denver)
Hi, I have a 1971 2.2 with stock P&C’s (we think ) and Webers. The car is in Denver (5280’)
Cam – Unknown at this time
Idle jets – 55’s
Mains – 120’s
Venturis – 27’s
CO% 3.5% - 6.0%
HC 6-800ppm
The timing is good, valve set unknown, plugs new.
The car has a heavy hesitation at mid throttle and the idle cannot be adjusted between ~700RPM (Dying) and ~1700 RPM.
Does anyone have any recommendations, does this sound like a float sticking issue maybe? Any other thoughts?
I have just ordered (Wayne’s) rebuild kits & float gauge and am planning on rebuilding the carbs this weekend. Does this seem a good place to start rather than a valve set….
Sam
"Trying to drive a 911 fast is like trying to throw a hammer backwards...." Unknown source
69 w/71 2.2L and Pretty Gulf paint!
Past P Cars - 90 C4, 84 Carrera, 74 Coupe
2007 Toyota Tacoma 4dr TRD & 2005 BMW 1200GS
Old 03-11-2008, 07:02 AM
Indebted user
p.s......
p.s. If any of you kind souls in Denver like coffee and free breakfast and want to help with a carb rebuild!
Old 03-11-2008, 07:04 AM
shbop's Avatar
Hi Sam, Are you sure the venturi's are 27mm? I think they should be 30mm, and 32mm for an S model. I'm not saying that it's the problem, only that it struck me as odd. My book says a 2.2"T" or "E" model would use:
Main venturi-- 30
Main jet-- 125
air cor.-- 180
Idle--55
Emulsion tube-- F26
These are just guidelines provided by PMO
Jon
Old 03-11-2008, 08:48 AM
