6 pin connector
First of all Merry Christmas to all of you.
I have tried searching for this but must not know the proper terminology. Is there a way to de-pin these molded connectors? The power wire for my tach has quite a bit of heat damage and needs to be repaired at the connector.
Old 12-25-2020, 08:48 AM
Not sure how to de-pin the connector > but several vendors sell replacement wiring harness
https://www.**************/products/f1l-b52-122i-108192
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 12-25-2020, 09:17 AM
Ok, that’s what I figured...thanks
Old 12-25-2020, 09:38 AM
ROW '78 911 Targa
timmy2's Avatar
I recast them, but I need the harness to do it properly.
New wire from 6 pin cast connector terminal and a new gauges daisy chain is the right way to do it.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-25-2020, 10:24 AM
walt's Avatar
A while back timmy2 here on Pelican made me a pigtail connector to splice into my existing harness. Send him an email or pm.
Walt
82SC 3.0
81SC 3.6
Old 12-25-2020, 10:25 AM
ROW '78 911 Targa
timmy2's Avatar
For the ignition switch connector (which this one is) I wouldn’t want to splice it due to the current it sees.
You could fairly easily strip the wires out of the harness back to the battery (2 reds), fuse panel (fatter red black and red yellow) and the thinner red black to the gauges. And send that to me or send me the wire lengths of each for your year.
Dennis
Old 12-25-2020, 11:40 AM
Ok thanks to all of you. Timmy2 I’ll be sending you a pm soon to get a quote on replacing this.
Old 12-25-2020, 06:24 PM
