WOLVERINE's Avatar
Power window to hand crank
Can someone please tell me what is the process to convert power windows to hand crank.
Do you use the same regulator?
does someone sell the parts online...is there a kit or something?
thanks
1977 Porsche 911S (Widebody)
Old 03-08-2008, 10:27 PM
Very simple process, just buy the entire manual assy and bolt in. You will need doorpanels as well. I bought used for $50.00, doorpanels for $75.00 for my '75.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 03-09-2008, 06:00 AM
WOLVERINE's Avatar
where did you get the door assembly?
Old 03-09-2008, 11:08 AM
I ROC!
mpeastend's Avatar
Pelican sells the manual window regulators. They (Porsche) redesigned the regulator assembly and it will require drilling some extra holes in the inner door panel to mount. It isn't a big deal and saves a good amount of weight. I went to the manual regulators in my IROC backdate. I suppose you could use used ones from earlier cars but they may also require some mods to a 77 door. Good Luck.
Old 03-09-2008, 11:35 AM
AutoBahned
RWebb's Avatar
if you pull the motors, or the entire assembly, can you post the wt.?
or if if anyone has this datum, can they post it?
Old 03-09-2008, 02:43 PM
Bump to the top for anybody that has ever removed a power window motor and weighed it. I'd also like to know what you found.
Thanks,
JR
Old 03-11-2008, 10:44 AM
David 23's Avatar
Thanks,
JR
+1
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 03-11-2008, 10:58 AM
laughac's Avatar
Send a message via AIM to laughac
+1
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 03-11-2008, 11:11 AM
Todd Simpson's Avatar
Electric: 3kg a piece
Manual: 1.8 kg a piece
from here
is this slope getting steeper? door panels
Old 03-11-2008, 02:05 PM
ImpressIVePower's Avatar
Smile
Hi
How much for all the wiring harness for the electric window? What year is the car?
Miguel
Old 03-11-2008, 02:53 PM
AutoBahned
RWebb's Avatar
The problem is "I used bathroom scales" as Peterfrans posted on that thread. So we can assume that the elec. "winder mechanisms" incl. the motor, are heavier than the manual, but it is not clear by how much.
The reason is that a bathroom scale is highly inaccurate - and barely repeatable at wts. that small. Or maybe they have really high quality bathroom scales in the Netherlands...
It would be great if someone weighed these things on a postal scale, or at UPS, Fedex, etc.
The wiring harness is not going to be much. The entire wiring harness for a highly electrified car like the 928 was pretty hefty tho (35 lbs.) - but just for a window will be small.
Old 03-11-2008, 03:15 PM
Odd. I distinctly remember reading that Porsche saved weight when it went to electric windows, when taking into account all the parts. As I recall, it specifically mentioned that the arms, gears and levers were much heavier in the manual one. I guess what I read was wrong, but I have no doubt that's what it said. I'm pretty sure it was in a Pano or Excellence article more than 10 years ago.
Old 03-11-2008, 04:47 PM
AutoBahned
RWebb's Avatar
IIRC, I read that in Aichele's book.
I have found that many Excellence articles have errors in them...
also it is not clear exactly what year mechanism was compardd with what other year...
Perhaps it saved wt. when they went to the improved scissors type lift mechanism...
At present, it is is a riddle wrapped in a mystery inside an enigma.
OK, apologies to the late, great amateur impressionist landscape painter...
Old 03-11-2008, 04:57 PM
The lifter rail at the base of the window will also need to be replaced if you go from the parallel regulator to the redesigned cross arm style.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 03-11-2008, 05:42 PM
