I hate filling up
Any solutions for filling up the 911SC without spilling and causing a puddle of gas on account of it venting out? I've had the car for 10 years and fill it the upside down nozzle way, 11:00, all different angles at the lowest setting. I think the new gas nozzles are worsening the problem.
I've replaced all the vent hoses in the trunk, and under the fender to the vapor tank. I've searched the archives for radical solutions. I have not replaced the charcoal canister. Is that the problem? I'm in denial that this car has to be a PIA to fill up and leave an environmental hazard behind. (gas puddle). Thanks for any solution.
78SC coupe, Silver Metallic |
fillin up
I turn the nosel around, sort of the hose is over the trunk lid, It works much better.
I don't even have a charcoal canister or anything fancy. I can tell by ear when its getting pretty full, and ease up. I think I've only overflowed once, and just a few drops at that. Just go slow at the top.
2012 911 Black Edition Cabriolet 2008 Cayman S Grey on Black - flooded, written off 1977 930 Turbo Carrera Black on Red #411 1987 951 Black on Black - sold to make room for the 930 1972 911 2.7 - I regret selling her every single day.... |
I hold the nozzle about 1/2 way in, with hose in normal (down) position, have to stand there while I fill, but works great. Charcoal cannister shouldn't have an effect. |
May want to check the metal neck about 8" down with a flash lite I had pin holes in the neck. Shine the lite from up under the fender, in the dark, and peek down the neck. I had to pull the neck out patch it with JB weld.
Herm 80SC |
BTW,
Putting the nozzle in upside down actually mostly defeats the auto shut-off feature on the nozzle. That definitely contributes to the 'puddle'. |
I tried every method mentioned and found that if I insert the nozzle in a few inches and slowly fill it works.
Now lets get to the issue you have with the gas!!!!
----------------------------- Ernie 81 SC |
On my '77, I just never filled it to the top. I had a gas smell if I did and maybe the puddle. Depended on the nozzle but this was in the '80's. I tried the upside down deal too. Seemed to me this was more to keep from nicking the paint on the rim of the filler flap opening. Rubber flap or no, one has to be careful.
Sleep Deprived and Grumpy
I have an 82 SC that I have only filled up 3-4 times however I have never had this issue? On my 73 with CIS this was always a struggle, I just never filled it to the brim for a while, then I replaced my filler neck, vent tubes disabled the canister and added a one way valve which worked great.
Did they revise the vent system over the years? or on most CIS cars is it the same, I have never really checked out my SC fuel fill area or vents. |
One, that is a frustrating problem for sure.
I can tell you this, I've owned 4 Porsches: one 911SC, and one 3.2 911. I've never had a chronic gas spilling or puddling problem. Something tells me that your problem can be fixed. I even fill the 911SC and the Carrera at Costco, where they have super duper fast pumps, and no spilling. Maybe you can take some pictures of what's going on. I think we can figure this out. |
AutoBahned
pull the hoses off the canister & see if it changes anything - if it does, then replace the canister.
Tired Member
I do not have that problem with my '78sc and I fill it all the time. So I would agree that it is not a design issue.
I do hate paying $3.70 a gallon, though!
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
I found the best way is to face the handle toward the passenger seat, and still got spill out several times before it's full. yes, I have to stand there holding tie trigger the whole time to release it when it starting to spill. My friend 964 doesn't have this problem.
Fat butt 911, 1987 |
Ferdinand Magazine
I have always done this on all my 911s and it works like a charm for me, so you must have a problem somewhere there. I would try pulling the hoses off one by one until the problem goes away and then take it from there. Maybe fill it with the hood up and a temp vent running over the top of the screen?
Sheriff at www.impactbumpers.com Brand support at classicretrofit.com/tuthillporsche.com 1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles |
Somatic Negative Optimist
Look at the small white plastic can in the trunk and follow the hoses. Hoses knicked? Charcoal canister blocked? I do not leave the nozzle on automatic; regular position a little pulled out and listen to the gurgle.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
resident samsquamch
I can't afford to fill up
Half tank is all I ever run! And I usually go for the turned handle trick, with the nozzel only half way in.
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Try different gas stations, or pumps. I've found over the last 25 years or so, filling the same cars using the same techniques as above (varying the insert angle and depth) that some pumps give me problems and others don't. They all will vary in their delivery rate and some are more sensitive to shutting off than others. The depth of the nozzle insertion into the filler neck is just as important as the angle of the handle with respect to the filler pipe. There is a fairly sharp bend in the filler pipe so I try to insert the pump nozzle in such a way that the flow of gas is in the direction that it needs to go.
JR |
I angle the handle towards the driver's mirror and pulled out just a bit (which is my estimate of what JR said). Fill up every time. Never spills.
Chris 87 Carrera Coupe - Guards Red on black 00 Carrera Cab - White on Navy 05 Carrera S - Atlas Grey on gray 86 951 - India Red on black - Sold |
Upside down works.....
It works because the nozzle follows the contours of the hard gas line between the fill door and the tank. On "normal" cars, doing it right-side up allows the nozzle to (likewise) follow the contour of the hard gas line path.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Ummm, my '79 is a PITA at the newest fastest pumps. I fill it up at half throtle (sp) until its flowing well then listen. Also I know roughly how many (eek) dollars to fill it from near empty so I don't get near the top.
