kodioneill's Avatar
need rear wheel bearing puller idea
took off rear axles 1974 911. i want to replace my rear wheel bearings. any ideas out for a puller other than the $232.00 bp-90.
thanks for the help.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-12-2008, 02:01 PM
You can rent a slide hammer bearing puller from autozone or kragens and use that. It destroys the bearing, but that's ok since you'll be replacing that...
Old 03-12-2008, 02:55 PM
sjf911's Avatar
I used this technique:
Rear Wheel Bearing Removal
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-12-2008, 03:08 PM
kodioneill's Avatar
i like it
1982 chiffon 911sc
Old 03-12-2008, 03:21 PM
9elf's Avatar
Option 2:- If you are handy with a lathe you can turn one of these up mate.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan.
“Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan.
Old 03-12-2008, 05:24 PM
911quest's Avatar
Harbor frieght now offers one you will still need a slide hammer to get the hub off.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=45210
Tony Proasi
1969S
1957 VW Pickup
Old 03-12-2008, 05:44 PM
kodioneill's Avatar
this will do the job of BP-90 puller?
1982 chiffon 911sc
Old 03-12-2008, 05:46 PM
911quest's Avatar
I have never used the one Harbor freight offers I use one that was offered about 10-15 years ago for FWD VW/AUDI's and it works on 911/914 etc. With out having it in my hands I don't see why it wouldn't work....
One thing that can be tricky is removing the outer section of the bearing race as it wants to stay with the hub I carefully use an air chiesel to drive it off. You can see in one of the posted pictures the bearing clamp that is another way to get the inner race off.
Tony Proasi
1969S
1957 VW Pickup
Old 03-12-2008, 05:56 PM
Install the new bearings by pressing only on the outer race. Chill bearing in freezer and heat housing. Pull wheel hub into bearing using spindle nut and extra washers. No pounding during installation of hub or you'll "Brinell" the races in the new bearing possibly ruining it or shortening its life.
Old 03-12-2008, 07:09 PM
