paslantnose's Avatar
clutch or trans, what are the odds?
Lost all gears after a full throttle through burst first gear and going for second gear.
At the shift, the engine just revved and no second gear.
No gears, not even reverse.
Trans made no sounds whatsoever, no noises at all when clutch is released with engine running.
What are the odds?
Trans or clutch?
1980 911SC Slant Nose
Can you say MegaSquirt !
Old 03-11-2008, 03:57 AM
disconnected shift coupler???
Tony G
2000 Boxster S
Old 03-11-2008, 04:59 AM
Max Sluiter
Flieger's Avatar
The nut/bolt on the shift rod clamp in front of the shift coupler is my guess. I just replaced the ball cup+shift rod bushings. I had to disconnect the shift rod but did not get it back together in the right position. I could not get any gears, just grinding. After many adjustments, I got it to shift better than ever. The nut/bolt is a 14mm. I used two open ended wrenches.
Old 03-11-2008, 05:05 PM
Well, put it up in the air to have a look.
The axle stub that the inner cv joint slides onto is sheared off just outside of the seal (no oil loss).
Seems like an uncommon failure point?
Old 03-11-2008, 05:39 PM
Whoa. How 'bout a pic?
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 03-11-2008, 05:42 PM
I'll get a pic or two and put them up.
Old 03-11-2008, 10:10 PM
RETIRED
Joe Bob's Avatar
Sounds like a CV.....
2012 ML350 3.0 Turbo Diesel
Old 03-11-2008, 10:20 PM
The piece that broke....
Here's the piece that broke, item #12 in the diagram below.
Anybody have items number 12 & 13 ???
Old 03-11-2008, 10:48 PM
AutoBahned
RWebb's Avatar
wow - that's unusual - can you post a pic?
Old 03-12-2008, 12:41 PM
RETIRED
Joe Bob's Avatar
Drive flange and the bolt? Sounds like something got loose.....
Old 03-12-2008, 12:49 PM
I'm not thinking anything got loose, it was a very clean shear just outside of the seal line.
It appears to simply be a torsional overload.
I was able to just pull the broken shaft out and remove the broken bolt with needle nose pliers.
It looks like a new flange and bolt & I'll be right back on the road again.
Yes, I will upload some pics asap.
Old 03-12-2008, 05:54 PM
