Guest
Posts: n/a
Ok
I give up I cannot find the pressure/ flow ratings for the standard 3.2 Carrera injectors anywhere. Bosch part number is 0-280-150-158. Any help is appreciated. Chris |
Guest
Posts: n/a
I just got back my injectors from Marren Motorsports. Here are the results-
http://members.rennlist.com/jdaniel/injtest.jpg These are stock Bosch units from an '87 911. ------------------ Dan Tolley 1987 911 Coupe http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=294 [This message has been edited by JDaniel (edited 04-29-2001).] |
Guest
Posts: n/a
Thanks for the info this helps. Any idea of the fuel pressure specs for the 3.2 ?
Chris |
Guest
Posts: n/a
Hope this helps. These are the specs if you are measuring at the fuel rail (not really injector rates). Just fuel pressure...
Engine off----- 2.5 bar (36 psi) Engine running- 2.0 bar (29 psi) Engine running, vacuum hose removed from pressure reg.- 2.3-2.7 bar (33-39 psi) Are you testing the fuel system pressure? ------------------ Dan Tolley 1987 911 Coupe http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=294 [This message has been edited by JDaniel (edited 04-29-2001).] |
Guest
Posts: n/a
Of course the amount of fuel changes as pressure changes. If my memory serves me correctly from my Bosch days, I think fuel rates are measured @ 45 PSI. I have not been able to find a link to the fuel rates for all Bosch injectors. Anyone know of a link so that we can find flow rates for FI??
Guest
Posts: n/a
Here is a link that lists a fair number of injectors:
http://www.autospeed.com/A_0102/P_2/article.html You are also correct in that capacity is normally listed at 45 psi. The test results for the 0-280-150-158 injectors posted were based on a very short pulse time. I am looking for ratings as per the above link if anyone has them. Thanks Chris |
Guest
Posts: n/a
This is also an interesting general discussion on Injectors which touches on the testing procedures.
http://modigliani.brandx.net/user/toeknee/injectioninfo.htm |
