Failing Brake Light Switch
I noticed today in the reflection of the truck with a chrome bumper behind me that my brake lights are not coming on without more pressure than it should be.
I had this problem with my '60s English sports car. I constantly was replacing the pressure switch. It would last a year or so, and then go bad. Once I learned that it was a common problem with the English switches these days, I gave up and made a bracket and electrical switch so that my brake lights now go on even when I just start to think about braking.
Anyone have similar experiences with our cars? Or do I just replace the switch and it should be good to go for a long time (bleeding the fluid of course)?
Thanks,
Jay
Old 03-13-2008, 05:56 PM
danger frog
superwrench's Avatar
What kind of car do you have? On my '86 911 i replaced the two electrical switches on the master cylinder,bled system,no problem!
Old 03-13-2008, 07:56 PM
3.2 CAB's Avatar
2nd on what car??? If it is a Porsche, change the switches out. What you are describing are very common symptoms of bad brake switch/switches.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-14-2008, 06:46 AM
Actually, I just looked at the part in the Pelican blow up. It looks like a manual switch, not a hydraulic switch. Are these adjustable to where they light up? This is for my 1973 911.
Old 03-14-2008, 09:18 PM
3.2 CAB's Avatar
That is why the car information would have been helpful to have. I guess that your brake switch is mounted in the pedal cluster. Some can be adjusted, if still good.
Newest additions-
others...
Old 03-14-2008, 09:42 PM
Go here:
http://66.236.61.177/showthread.php?t=390422&highlight=brake+switch
Sherwood
Old 03-14-2008, 10:00 PM
