Jandrews's Avatar
Post Your Corner Weights and Alignment Specs Here
My car is a '70E with 2.4S motor modified to 2.7RS specs with MFI and 911/01 transmission with 7:31 R&P. It has 9" and 11" flairs running 225x17 fronts and 275x17 rear tires. 23/31 torsions and 19mm sways front and rear. Elephant racing bushings/monoballs front and rear with Sway-A-Way adjustable spring plates. All sound deadening removed from interior and engine bay. Lightweight carpet set, RS door panels, fiberglass ducktail, as well as front and rear bumpers. Sparco America lightweight racing seats.
Total Weight is 2,187 wet
Corner weights are as follows:
LF: 436
RF: 394
LR: 685
RR: 672
F/R Ratio: 38/62
Front
Camber: -1.1 degrees
Toe: 0"
Rear
Camber: -1.2 degrees
Toe: 1/16" rear
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3 (Sold)
Old 03-16-2008, 10:34 AM
Driving member
jester911's Avatar
L/F 611 R/F 566 41.25%
L/R 868 R/R 808 58.75%
With driver weight and a 1/2 tank of gas
Don't have the alignment numbers off hand.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 03-16-2008, 10:51 AM
