Here's a Heck of a Thing
So I'm feeling all good about R&R'ing the engine on my cabriolet (including getting the word this morning from Bob at Anchor Atlantic that my heads had arrived OK). I decide as my dinner is warming in the microwave to go out and check on something that I've kept forgetting about.
The issue was the head studs. They looked pretty much all the same except the bottom row on both sides seemed newer (a little shinier, maybe). I figured they were installed at some point during a broken stud replacement episode (the history on the car is spotty at best but there was a supposed rebuild in the past) and thus appeared newer than their topside brethren.
Grabbing a magnet off the fridge, I began checking the top and bottom studs on both sides.
Gee, that's funny, the magnet does not stick to any of the bottom studs. They must be -- wait -- how can this be? -- gulp -- dilivar studs.
Yesiree, a bit of a Porsche punch in the gut.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-18-2008, 05:34 PM
Scott R's Avatar
Yea, thats an SC 3.0 alright, had two steel, and the rest dilivar. PO did a lousy job of putting it back together and it grenaded, all new steel and a profession rebuild later and I still wonder sometimes if they are all still OK.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-18-2008, 06:56 PM
Jeff Alton's Avatar
NO big deal, the bottom row comes out pretty easy and new factory steel studs can be had pretty cheap.
Cheers
www.turn3autosport.com
Old 03-18-2008, 07:38 PM
Why didn't they use steel to begin with?
Old 03-18-2008, 09:04 PM
Jeff Alton's Avatar
The thought at the time was that the dilivar expansion rate was more similar to that of the aluminum cylinder and they were suppossed to reduce problems with studs. Too bad it did not turn out that way in the long run.....
Cheers
Old 03-18-2008, 09:19 PM
I never realized that dilivar studs looked so similar (yet still slightly different) compared to normal steel studs. I thought I was well clear of the stud issue on this one, but, alas, no dice.
Time to bond with my assistant crew chief as we remove 12 of these #$%@* gems.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-19-2008, 05:20 AM
MAGA
Tim Hancock's Avatar
Brian
Brian, my SC came with 12 dilivar studs on the bottom also....it is normal. I replaced the 12 lowers with new stock steel ones.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 03-19-2008, 05:41 AM
Slumlord
Porsche_monkey's Avatar
Contrarian opinion: If they are not rusty leave them in.
Old 03-19-2008, 05:49 AM
Hey, Tim, I know dilivar lowers are normal as our cars left the factory, but my cab is a high-mileage car (140,000 miles or so). I figured the stud issue was corrected by whomever was last in this engine (yep, silly me for thinking that). I'm glad I checked this out with the magnet, so at least I know what I'm dealing with.
I'm listening.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-19-2008, 06:01 AM
Slumlord
A lot of what you read is just people repeating the mantra, dilivar is bad.
Why do they fail? From everything I've read they fail from corrosion. Every failure I've heard of was a rusty stud.
I researched this a fair bit when I rebuilt my 2.7 engine. I went with dilivar.
Old 03-19-2008, 06:18 AM
Dilavar is a cool material. Strength like steel and expansion rate like aluminum. Just very susceptible to corrosion. If you pick up the first edition of Bruce Anderson's "911 Performance Handbook", he makes a very strong case for Dilavar studs. If it weren't for the corrosion problems leading to breakage, Dilavar would be the optimal material for the studs as the threads in the case would in no way be unduly strained.
The bottom line is: how do you keep your heads attached to the motor for a long, trouble-free time? I tend to agree with PBH - although not for the aluminum case (and I do have to qualify this: my present knowledge comes from reading, not experience. Quit working on P's professionally 15 yrs ago). Here the likelihood is greater that a properly torqued Dilavar stud will snap rather than a steel pulling the threads out of the case. With a big bore on a mag case, I'd prob tend to go with good Dilavar studs on the hot (lower) side.
Either way, you shouldn't see it as a time-bomb in the back of your 911. Not a steel studs pull threads and not all Dilavar threads snap. You're talking about turning a relatively low risk to a very low-risk.
Old 03-19-2008, 06:34 AM
BTW, Anderson doesn't go back on his opinion in the new issue of the book - he kinda skirts the issue elegantly :-)
Old 03-19-2008, 06:37 AM
dilivars last longer now because the surface is protected with paint. any old unpainted dilivar needs to be replaced when the engine is torn down. they get a rust band where they are exposed, like in the gap between head and cylinder and cylinder and case. the rust penetrates and the stud snaps. they already lasted quite a long time, mostly, so too chancy to leave them in.
206 637 4071
Old 03-19-2008, 06:38 AM
GaryR's Avatar
Send a message via ICQ to GaryR
I agree with John (that's easy to do anyway...). The picture shows some corrosion starting on the lower studs, I think it would be insane to leave them in with the engine dismantled.
Gary R.
Old 03-19-2008, 06:51 AM
That's correct. As John says, there is corrosion on the exposed portions. I'll replace them. I just wasn't expecting to find them at all.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-19-2008, 07:02 AM
Why didn't Porsche use Vibranium for the lower studs? That material works great for Captain America's shield.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-19-2008, 08:21 AM
do anything John says...
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-19-2008, 09:26 AM
MAGA
Brian
FWIW Brian, prior to taking my SC engine apart, I had zero broken Dilivars.....two of them snapped upon removal.
As others said above, replace them.
0% Liberal
Old 03-19-2008, 12:47 PM
Thanks, Tim, I'll approach the removal with caution.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 03-19-2008, 01:10 PM
MAGA
Brian
Brian, I used heat to soften the loctite and remove the studs, but I was trying to make the point that they broke when I was removing the nuts on initial tear down..... I would have been royally p!ssed if I had decided to re-use those lower studs had they not broken, only to hear a snap during re-assembly. Just to be clear on what I did....I simply replaced the lower dilivar studs with steel ones to match the upper studs (which I did not replace).
0% Liberal
Old 03-19-2008, 01:42 PM
