Eye of the Toiger
MSD problem please help!!!!
Howdy,
My poor old mechanic is having a hell of a time tunnin g my 3.0. The timing at idle is set at 35 degrees before TDC if he goes below this the engine stalls when he moves the distributor below 35 He says it should be at 5 degrees before TDC and he can't check the timing. The engine runs ok at 35 degrees but idles high 1600 rpm. Is this the MSD?? If so what adjustmen t needs to be made to the MSD? If some one can shed some light I'll owe you a few jars. Matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
I don't think it's your MSD. The MSD just works off the trigger signal from the mag pickup in the distributor, it doesn't do any advancing or retarding.
John Adams 1980 ROW 911SC |
Wer bremst verliert
Did you check the instructions on the MSD for which wire to clip? I think you need to clip one of the wires to have it trigger properly. Or that might just be the RPM signal or something else. Anyway, I'm pretty sure you need to clip a wire.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
the polarity is wrong on the msd signal wire. BTDT.. switch the purple and green wires and it will work perfect. I assure you
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Eye of the Toiger
Hi Ben,
He did that and he reckons it runs worse. Matt
Capitalist and Patriot
FWIW When I 1st installed my MSD I had the same exact symptoms as the poster states... ![]() Then I stumbled across this same recommendation and it made all the difference ![]() You also need to clip the (red) wire on the side..the blue wire is for 6cyl...This is located under the black button w/small screw in middle of it on the side of the MSD unit..
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
911 user...
Link to the MSD install instructions: http://www.msdignition.com/pdf/6%20series/6series.pdf
page #4, cut the red wire for 6 cylinders. The MSD ignition ships in 8 cylinder mode by default. enjoy.
-Will 911SC & Audi S4 Count those blessings every night! |
