-   -   Cabriolet Top Best Practices (http://forums.pelicanparts.com/porsche-911-technical-forum/399456-cabriolet-top-best-practices.html)
1982911SCTarga 03-21-2008 04:47 AM
I've been searching and haven't really found what I'm looking for in terms of establishing a best-practices routine for folding and unfolding a cabriolet top, particularly the earlier manual tops.
Should one always unzip the rear window prior to folding? I've also read about placing a large towel over the rear window section after unzipping and before folding the top back. Will the boot cover fit OK over that configuration?
Also, there are a set of procedures on a card on the right-hand visor, but mine's faded and I can't make out what it says. Can anyone post the instructions here? (The '83 owner's manual makes no mention of cabriolet tops.)
What say you veteran cab owners? Thanks!
Brian
imcarthur 03-21-2008 05:08 AM
http://members.rennlist.com/imcarthu...s-IMGP3263.jpg
Ian's Rules for Owning a 911 Cab
  1. You are the coolest of cool. You are allowed to sneer at all coupe’d drivers. But be kind, because they are ALL envious on a sunny day whether they admit or not. In the picture above, you can clearly see me sneering at Mark in his 930 on the Niagara Parkway - Niagara Falls, Canada.
  2. Top down as often as possible. If you are not top down, the car should be in storage. (or your wife is along for the ride).
  3. Always zip the plastic window out & put a towel on it when folding the top down. This saves the window from wrinkles & cracks & eventual rear obscurity so you might not see that cop car following you.
  4. Practice putting the top up quickly. The only iffy part is zipping the window up - be gentle so you don't rip out the zipper stitching. And THAT is not a fun job to replace - think big sewing needles & blood.
  5. Treat the window with a clear plastic window cleaner every couple of washes.
  6. Never, repeat, never put the top down in freezing temps. I know this breaks Rule 2 but the plastic window is not cheap to replace.
  7. If it starts raining lightly, do not pull over to put the top up. Drive faster.
  8. If your top is manual, always push the metal bar into the fabric as you bring the top down. If it’s not manual, it probably soon will be.
  9. Wash your top every couple of years & spray with a silicone sealant. 303 if you're obsessed or any silicone canvas preservative will actually do the job.
  10. Buy sunscreen & keep it in the door pocket.
  11. Garage the car when not in use.
  12. Never leave the top down for extended periods of time. Always put it up so the fabric doesn’t remain creased & ‘folded’.
  13. When in motion, always have the cab boot cover buttoned down or the top can catch air, chafe & wear prematurely. Another big bill to avoid.
  14. You are the coolest of cool. Keep a pen ready to sign all of the autographs . . .
aj88cab 03-21-2008 05:21 AM
You might get some different opinions (imagine that on this forum) but this is how I care for my cab top. The rear window is always unzipped to drop the top. I always release the latches before unzipping to minimize stess on the zipper (the stiching acutally). Some folks do place a towel on the unzipped window before lowering top top, I generally do not. I do place a towel over the folded top before covering with the boot. There is a bar that folds over the top when it is lowered, I place this bar on top of the folded top, some folks like to place it in the folds of the roof. I did this once and found that the folded top sits a bit higher. After a day of highway driving with the boot on I found that the boot had rubbed on the roof liner and wore a couple holes thru the liner. Also if you look at the folds of the fabric with the bar folded inside the top, you might notice that it pinches the fabric on the sides. So now I put the bar on top and lay a towel over it. Never drive without the boot. Never lower or leave a wet top down. Keep it clean and treat it regularly with a good protectant like Raggtopp.
charleskieffner 03-21-2008 05:35 AM
the above is sooooo true. sneering at coupes with just some clown driving solo while you have the hot drop dead big boobed blonde/redhead/brunette in some see thru top, actually places you on the EXALTED LIST!
actually talked at length with verdone here in snobbsdale,az. they do all interior work for all mega high end cars and are contracted by north snobbsdale porsche for all their interior/ top repairs. the single worst thing for cab tops is DIRT/DUST!
the next would be bird POO!
and the next tree SAP!
those three are the worst culprits that they see. as we all know cab tops aint cheap. actually scarey spendy. everytime i take mine out i bring it back in to garage put top up(manual) and wet/dry vac interior and top for drill. you will be amazed at how much cleaner it is. the material holds dirt which is abrasive and soon kills the hell out of mega spendy material.
they also recommend 303 cleaner and 303 waterproofing.
i use the 303 about 2 times a year, during a simple car wash. as soon as i am done spraying off all suds and the car is clean i then take the wet/dry vac and suck up all the moisture i can and let air dry out of the sun.
next morning spray the hell out of it with 303 convertible waterproofing and let dry. i have NO LEAKS WHATSOEVER and have been in a couple of heavy monsoon rains with it.
also i replaced all the cab moldings top bottom sides etc. they are quite waterproof when new. i had some old ones when i first bought car and leaked so changing them out was the hot ticket.
the ONLY REASON i would ever buy a coupe is to track it!
plus with a cab its easy to throw roofing nails or beer bottles out the top at people chasing you! hahahahahaha! LOL!
Wickd89 03-21-2008 08:14 AM
One other thing. When I put down the top, I usually stop 1/2 way down to make sure the top fabric is nice and neat in the corners; near the hinges. Sometimes the fabric gets caught and causes fabric damage. This would avoid having to put a patch on the inside of the top due to rubbing.
I actually like driving with the top up sometimes; yes, even is Socal.
OH yeah, as I sit here, the weather man on ABC just told me that it is going to be 78!
I'm out of here to work, top down!!
Netspeed 03-21-2008 08:20 AM
+1 on checking the fabric when folding. Those locating pins can do real damage!
1982911SCTarga 03-21-2008 08:40 AM
This is very helpful information. On this topic:
I actually like driving with the top up sometimes; yes, even in Socal.
Do you guys ever drive with the side windows down, the top up and the rear window unzipped? Is this OK, or will the rear window get blown around and scratched or damaged?
Brian
Netspeed 03-21-2008 08:47 AM
Brian
I haven't but I think you might get some exhaust in the car from the vacuum effect of having that window out.....I could be wrong though.
charleskieffner 03-21-2008 08:54 AM
i have driven top up side windows open or closed and the rear unzipped no problem. no fumes just the sweet sound of headers. PCA national does not want cabs tracked with top up. in event of crash rollover metal cab supports could skewer driver/passenger. unlike zone 8 pca who said we had to run with TOP UP at speedfest after running (3) time trials with top down. have spoken to michael dolphin head of safety for pca zone 8 and he was going to look into it and confirm ruling.
top up at track , cabs DO HAVE rear vision problems. and closing speeds of some of the cars in your class beginner intermediate advanced is beyond NUTS!
my honest humble(yeah right) o-pin-yon..................TOP DOWN FOR SAFETY!
Netspeed 03-21-2008 09:13 AM
That makes a lot of sense for having the top down. I never realized that those supports and bows would turn us into Sushi! :eek:
carolinatrophy 03-21-2008 10:51 AM
My 1985 cab is my only car, so I drive it everywhere, all day, every day. All winter. Through the pouring rain. To go pick up groceries. If I'm driving, I'm in my cab.
And I'm fortunate. because I seem to have the only early cab that doesn't leak. Not a drop. The car is remarkably comfy and cozy in the rain, in the winter, on long trips... It's very useable and flexible as a daily driver.
But I agree that you should use care during the actual lowering process. Take your time, make sure the fabric isn't getting kinked, make sure the plastic rear window in laying nice and flat. Take an extra minute or two when lowering it and the top will last a lot longer.
But hell, if it gets damaged, just replace it. You're driving a Porsche 911 cabriolet for crying out loud! It's a small price to pay for such joy. Hahahahahahaha!
Jay Laifman 03-21-2008 11:07 AM
Temperature, temperature, temperature. I only put my top down when it's warm out and when I feel the window it's plyable, not hard. Yeah, there are days when I could be driving top down but don't and that's a loss. But, my original window is still great.
That said, right about now I put the top down and leave it down until forced to put it up in the fall.
One of these days, I'll get a hard top and I'd have a lot more top down driving during the cold months.
3.2 CAB 03-21-2008 01:27 PM
No Leak Top
Hey Paul, you are not the only "one" mine does not leak either.:D
On the thread topic. This is what I do:
1. ALWAYS UN-ZIP THE REAR WINDOW ZIPPER, IT RELIEVES STRESS ON THE ASSOCIATED PARTS.
2. ALWAYS USE THE "BOOT"
3. WHILE LOWERING, ALWAYS MAKE SURE THAT THE FOLDS ARE BEING DONE PROPERLY AND THE BAR IS SITTING WHERE IT SHOULD BE.
4. TAKE PROPER CARE OF THE FABRIC AND REAR WINDOW
5. KEEP THE TOP ADJUSTED FOR PROPER USAGE
6. WHEN RAISING THE TOP, I ALWAYS HAVE THE DOOR WINDOWS LOWERED A BIT, TO EASE THE CLOSING PROCEDURE.
7. WHEN RAISING THE TOP TO PUT IT BACH TO THE UP POSITION, MAKE SURE THAT THE SUN-VISORS ARE TURNED DOWN, TO BE OUT OF THE WAY OF THE LOCKING HANDLES.
8. MAKE SURE THE "LOCATING PINS/ FRAME STUDS ACTUALLY FIT PROPERLY INTO THE HOLES IN THE TOP OF THE WINDSHIELD FRAME.
Hopefully, some will find this information useful.
Good luck to all with a Cabriolet!!SmileWavy
I replaced my top a fews years back now, and I have not had any leakage after the top and all of the seals were replaced. It did take some time to get it all done just right. A lot of hand fitting, trimming, adjusting, gluing, etc. I pretty much swore off of ever doing another. It almost drove me insane. :eek:
I now know why the shops wanted soooo much $$$$$ to replace the top. Hopefully I will never have to do anymore work on it, but it did come with a "LIFETIME GUARANTEE" the manufacturer even sent me a second, rear section, with the window--FREE!!! So now I have a great looking top, plus a new rear section complete with the zip-out window:D
I do know that a few bottles of Crown Royal were consumed, along with several bottles of Cristal, tended to take some of the mental pressures away. But the nectar from the gods, had to be put off, till that day-into-evening had come and work was finished for that day, I would have hated to see what it would have looked like had the Crown and the Cristal had been in use while trying to do all of the hand fitting, trimming, and gluing. It has now been about 6yrs since the replacement was finished, and it still looks brand new!SmileWavy
1982911SCTarga 03-21-2008 02:06 PM
I was just out looking at that visor information card that I mentioned earlier. With tweezers, I was able to gently slip it out of its aged plastic sarcophagus without damaging it (I swear, we're part-time archaeologists with our cars). Anyway, the card (it's about the size of a business card) had been flipped over so you couldn't read it. Here's what it says:
http://forums.pelicanparts.com/uploa...1206133253.jpg
Heck, that's all you need to know! Like I said, the '83 owner's manual says nothing about the cabriolet model at all.
Brian
911boost 03-21-2008 02:12 PM
This is all great advice. About the only other advice I can give (my 86 3.2 was a cab) with an automatic top, is to always make sure both motors are turning. It might even be safer to just disconnect the rear motors, and only use the front motors to lock and unlock from the windshield.
Bill
Netspeed 03-21-2008 02:19 PM
Bill
+1
I learned that lesson when the right front cam actuator hung up. Bam!....the cable popped out of the motor :(
911boost 03-21-2008 02:21 PM
You got lucky. The new owner of my cab actually had a motor fail, and snapped a bow in the top. You never never never want to price one of those...
Netspeed 03-21-2008 02:46 PM
I know I got way lucky. I've heard of some people ripping the top actuator/gear assembly right out of the sheet metal.
Car Guru 03-21-2008 09:27 PM
All of this is good advise, I have nothing to add as it's all been covered <-No pun intended :D in great length. I will say this about having a cab, I am envious of coupes on days not suited for top down driving, winter, overtly windy days, extreme cold etc... but I feel like a celebrity when it's ideal for a top down ride, words cannot describe it. Honestly when I'm out in my car I feel like I'm driving something way more special than a Ferrari or even Lambo. I know thats pushing it but it's the way I feel, everyones mouth seems to be drooling when I roll by and older guys point and smile.... blaaaa blaa I could go on. Cab life does rock for sure.
-Ryan
mack6820 03-22-2008 08:43 AM
I never unzip the window. Maybe I should but most of the time, I make stops at grocery stores, blockbuster, etc.. So it would take alot of time to raise and lower the top your way. Also my boot doesnt snap down so it blows around too much. The snaps are in the wrong position from the previous owner. I guess I'll just replace the top in a few years. Their not very expensive.
SCWDP911 03-22-2008 09:11 AM
Kind of like Car Guru was saying, I have to admit that I much prefer the looks of the coupe if compared to a cab when the top is up. I only like the cab looks when the top is down. but then I guess that is the way it should be in the universe, right?
3.2 CAB 03-22-2008 11:47 AM
mack6820, why don't you just add the additional snaps to you boot. Don't bother to remove to one already there. Just add what you need that will match the snaps on your frame? They don't cost much, and it would make sure that it was not blowing around.
mack6820 03-22-2008 04:42 PM
I will when I have time. Just havent bothered with it yet. Been driving it without the cover for 2 years, no problems.
JJ 911SC 07-23-2009 09:40 AM
I just got a 1983 Cabriolet and it came with the windscreen but the "holding part" on the driver side is missing. I try to located on the Porsche CAT or on Pelican and others site without sucess.
If someone got the part number or a photo (make my own bracket), please forward.
Cheers
J.J.
http://forums.pelicanparts.com/uploa...1248367080.jpg
http://forums.pelicanparts.com/uploa...1248367126.jpg
motorcop 07-23-2009 02:47 PM
I have an 84 Cab and am totally in love with it. My son and I took a 300 mile round trip run to the Jersey Shore on Monday, top down both directions, tunes playing, having a great time. I too unlatch the top prior to unzipping the rear window, and then place a towel over it to avoid chafing, seems to work well. As far as the windscreen that JJ911SC is referring to I did not even know that those were available. Will they fit an 84 model? If so where can I get one?
bonkers 07-23-2009 05:19 PM
Sir, I approve wholeheartedly of your rules and your attitude. Of course I should expect no less from one with such a noble name.
Regards,
Ian. :D
http://forums.pelicanparts.com/uploa...1248394669.jpg
kidrock 07-23-2009 09:03 PM
http://forums.pelicanparts.com/uploa...1248408122.jpg
RULE #1: Drop top.
RULE #2: Carefully place surfboard or large-breasted female in passenger seat.
RULE #3: Drive like a demon.
:D:D:D
Chuck Jones 07-23-2009 10:37 PM
The only thing I notice in reading through this entire thread.....was that no one ever mentioned lubing the pivot points in the top mechanism. I keep a little tube of that clear silicone lube and put a bit on my finger and work it into the cross sections where the cross braces are bolted or pinned together. I also put a light coating of that silicone lube on the lock-down mechanism and wheel at the front where it cams the top down. I seems that you would want to keep these X joints lubed to prevent them from binding. Just my opinion for what it's worth.
nyne11 07-23-2009 11:41 PM
Take a look at this old thread http://forums.pelicanparts.com/porsche-911-technical-forum/431033-wind-deflector-wind-stop-windschott-finally-got-one.html?highlight=Windschott They come up on Ebay form time to time....good luck.
Dave.
Chuck Jones 07-23-2009 11:46 PM
My 87 factory slant came without a windscreen, and it wasnt' listed on the certificate of authenticity or the option codes. Is this something that came with the car, or is it an aftermarket item>>?? I'd be interested if it was something that served a useful function....but I dont see any slots or brackets wehre such an accessory would be mounted.
JJ 911SC 07-24-2009 05:13 AM
Not sure it was an option back then (the Authenticity Certificate is in the mail).
The right inside bracket is screwed on the mechanism. I got the bag for it and if my memory is good it is say Porsche on it. I will check tonight for the part number.
At a Cruise Night Wednesday, I talk to a guy that got one on his Mercedes and he mentioned that it is very effective.
http://forums.pelicanparts.com/uploa...1248436608.jpg
http://forums.pelicanparts.com/uploa...1248437520.jpg
Laneco 07-24-2009 07:23 AM
You guys forgot the most important rule!
HIDE THE KEYS FROM YOUR WIFE!!! :D
I LOVE driving Steve's cabby! Cabs ROCK! They are just soooo dang sexy... Just wish he hadn't lowered the seat because I can barely see out of it. I think he did that on purpose. :rolleyes:
angela
http://forums.pelicanparts.com/uploa...1248445388.jpg
Chuck Jones 07-24-2009 09:11 AM
Please do post a part number. I was totally unaware that a wind screen even existed for the cabs up to 89. Now I'm on the hunt....
JJ 911SC 07-24-2009 09:29 AM
Angela
Hide the keys, I don't have too... Pick one of the following reasons;
A. She does not drive standard;
B. She can not reach the pedals;
C. If she could reach it, she could not depress the "foot long" clutch; or
D. All of the above.
If you pick D, you are correct. Mind you that 2 months ago I was not even dreaming of owing one and out of the blue she send me a link to one for sale (a disaster waiting to happened).
I did some research and came upon this one on a Sunday, saw it on the Monday and made a conditional "technical test result" offer and was accepted and she was mine that Monday night. The Compression Test result came in at 160- 170 Psi across the cylinders.
So, thanks to her, my 45 years old dream finally came through (I saw my first 911 back in 1964).
J.J.
Maybe one day the Black & White beauty will cross path...
http://forums.pelicanparts.com/uploa...1248452165.jpg
JJ 911SC 07-24-2009 04:42 PM
Well it's the usual good news/bad news scenario...
The good news: After going over the frame over and over, I did find the part #... and it is definitely a Porsche item, my windscreen is stamp with, 993 561 179 00 DEZ. I punch it in Pelican 993 catalog and it come up with a "superseded #" message which mentioned that the # has been replace with # 993 561 979 03 DEZ which is available for purchase.
The bad news: Well for a modest $420.65 with a possible surcharge of 20% as it's coming from Deutschland. it could be yours. That is about 2.5% value of what I paid for the whole car.
So at $20 on e-bay, Dave made a very good deal (see old thread refereed on this thread entry #29).
So, I'm half way there, as soon as I can see what the "male" bracket look like, I'll make one.
J.J.
http://forums.pelicanparts.com/suppo...eys/yltype.gifhttp://forums.pelicanparts.com/uploa...1248478124.jpg
http://forums.pelicanparts.com/uploa...1248478227.jpghttp://forums.pelicanparts.com/suppo...eys/yltype.gifhttp://forums.pelicanparts.com/suppo...eys/yltype.gifhttp://forums.pelicanparts.com/suppo...eys/yltype.gif
Chuck Jones 07-24-2009 05:17 PM
Holy Windscreens Batman.....I'm starting to like....and get used to the feel of a light breeze blowing softly across the back of my neck as I cruise through the countryside taking in all of God's creations....
imcarthur 07-24-2009 06:02 PM
Here's an old thread about windscreens Wind blockers for Cabs - 993 version fit Carerra?
They are available from our host for $457.50 Cabriolet Wind Stop (Deflector)
But the hair blowing free is part of the fun. Just avoid long scarves however or look up how Isadora Duncan died.
Ian
nyne11 07-24-2009 06:27 PM
[QUOTE=JJ 911SC;4796876]Well it's the usual good news/bad news scenario...
J.J.
J.J. you appear to have a later model than the one I purchased which mounts entirely differently. Like this one.
http://forums.pelicanparts.com/uploa...1248484810.jpg
The guy I purchased mine from said it came with his 930. Certainly fits mine like a glove and really makes a difference. Good luck.
http://forums.pelicanparts.com/uploa...1248484976.jpg
http://forums.pelicanparts.com/uploa...1248485089.jpg
t951 07-27-2009 03:27 PM
Are there areas on the cab that are supposed to be lubed? If so, how often and what has been determined to be the best lubricant?
Also, is it easy to change the seals? I am going to have to change ALL of the seals as they are all old and mostly damaged and dry rotted....
JJ 911SC 08-04-2009 03:46 PM
If anyone need a "pdf" version of the Cabriolet Insert that came with the 1983 Owner Guide, let me know (supply an e-mail address).
J.J.
