-   -   How did you "hang" your Flowmaster muffler? (http://forums.pelicanparts.com/porsche-911-technical-forum/399802-how-did-you-hang-your-flowmaster-muffler.html)
rennch 03-22-2008 11:16 PM
I have a dual-in, dual-out Flowmaster 80 series muffler that I need to mount. Anyone have pics of how they mounted theirs?
JohnJL 03-23-2008 12:04 AM
Mine hung just like the standard..no pics on this laptop but searching on my name and exhaust should show up.
rennch 03-23-2008 12:14 AM
The straps were long enough?
JohnJL 03-23-2008 02:40 AM
no, just longer straps
Oh Haha 03-23-2008 05:46 AM
There may be a couple of ideas in here: ;)
http://forums.pelicanparts.com/search.php?searchid=1343355
len911 03-23-2008 06:10 AM
Funny, I just did this yesterday on my track car... I used the OEM bracket and bent it back. I used a piece of scrap Al to make a J and attached it to the two lower bolts that hold the engine to the rear cradle. I had to bend the OEM bracket to "straighten" the muffler up since I was concerned about the intake pipes touching the exhaust pipes.
Using (4) 5"dia. hose clamps and there is no movement at all. I'm happy. Including pictures. It was my first time welding, and even thought the welds are not too pretty, they will hold.
I bought the muffler (best price @ Amazon), (4) 90deg pipes and a u pipe to get the right angle needed for the connection from the headers up to the muffler intake (Summit racing). Total cost about $260 including, 02 bung, 2 hose clamps, gaskets and flanges. Had to buy a welder, but it was something that I always wanted to tackle... Borrowed a Sawzall for the cuts and a grinder for final shaping. I think it came up pretty good and it took about 5 hrs! Enjoy... Lou
http://forums.pelicanparts.com/uploa...1206277152.jpg
http://forums.pelicanparts.com/uploa...1206277193.jpg
http://forums.pelicanparts.com/uploa...1206277242.jpg
http://forums.pelicanparts.com/uploa...1206277264.jpg
http://forums.pelicanparts.com/uploa...1206277287.jpg
Bill Verburg 03-23-2008 08:02 AM
here's mine
http://forums.pelicanparts.com/uploa...1206284526.jpg
http://forums.pelicanparts.com/uploa...1206284550.jpg
gumba 03-23-2008 08:11 AM
I welded a plate on the back of the muffler with 2 holes towards the bottom. It mounts to the 2 lower case studs.
GaryR 03-23-2008 08:29 AM
Me too, a 6" piece of 1"(?) angle iron, then positioned another piece and mounted it to the two stud (circled in photo). once cinched up to the headers I welded the two angle pieces together and to the 80 and that's it. I'll take a picture of the whole assembly next time it's in the air (tomorrow)..
http://forums.pelicanparts.com/uploa...1206286232.jpg
vreference 03-23-2008 08:46 AM
Bill,
I believe those are the same headers that came with my car, who are they by?
Any of you flowmaster guys have YouTube video? I'm interested in seeing what this sounds like.
tcar 03-23-2008 08:58 AM
Just longer SS hose clamps. Quick. Easy.
PCA7GGR 03-23-2008 09:03 AM
I (actually Scotty at the local muffler shop) used the same approach as most of the previous responses - a welded on bracket attached to the lower studs on the engine. I had replace the short studs with longer ones to mount the jackpad/towhook and there was enough meat left on the stud to mount the Flowmaster. It can be dropped without removing the rear valance.
http://forums.pelicanparts.com/uploa...1206288031.jpg
http://forums.pelicanparts.com/uploa...1206288047.jpg
eapcpa 03-23-2008 08:35 PM
So you guys are sending the exhaust into each side and out each side. Isn't one side of that muffler a dual inlet and the other side a dual outlet? How does that affect the sound and exhaust flow or is it a special cross-flow muffler. Can you post a part #. Thanks.
9elf 03-23-2008 10:40 PM
Excellent photo's.
Len911, did you weigh that before mounting by chance?
rennch 03-23-2008 10:44 PM
Guys, thanks so much. Somehow I missed these responses.
Lou, you might have inspired me to take a crack at welding this up myself. :) Did you eventually seam-weld the tubes after you tacked it?
rennch 03-23-2008 10:45 PM
Bill V...where did you get the extra long muffler straps?
rennch 03-23-2008 10:46 PM
Ed, mine is a Flowmaster 80 Series, 2 in, 2 out. Flowmaster 42582 is the part #.
len911 03-24-2008 03:52 AM
Total weight was 24lbs 9oz versus my Supertrapps 14lbs 8 oz. So we are talking about 10# difference. Hopefully I'll get some more torque... Noticed my car was idling really rich after install. Sent for some smaller idle jets for the 46IDAs... Yes I did weld up all the seams and flanges, it is not going anywhere :) Lou
Bill Verburg 03-24-2008 05:52 AM
Originally Posted by vreference (Post 3844570)
Bill,
My headers are custom B&B. They start w/ a std. 1 3/4" header set, then put heater boxes w/ 964 heat inlet and 911 heat outlets around it.
I've used the same header set on a 964 and 2 993 engines mounted in the C3 chassis.
Bill Verburg 03-24-2008 05:53 AM
Probably Fabspeed, it came w/ their header muffler kit.
