sway bar question
Have access to a 19mm rear sway bar for my 72 what size should i go with on the front. It will only be used on the street.
I would use a 19mm adjustable bar in the front with it. That should give you a range of adjustment to balance the car's handling. Your other choices for a stock look are the 16mm and 18mm fixed OEM bars. All the larger OEM bars are "under the body" types, not the "thru the body" type used in '72.
TT |
| All times are GMT -8. The time now is 10:24 AM. |
