sway bar question
Have access to a 19mm rear sway bar for my 72 what size should i go with on the front. It will only be used on the street.
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
I would use a 19mm adjustable bar in the front with it. That should give you a range of adjustment to balance the car's handling. Your other choices for a stock look are the 16mm and 18mm fixed OEM bars. All the larger OEM bars are "under the body" types, not the "thru the body" type used in '72.
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
