-   -   915 rebuild Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/399867-915-rebuild-questions.html)
Ohio911 03-23-2008 12:26 PM
Well I am spending Easter morning looking over all of my 915 internals. It is a 72 with the sealed guide tube. The Transmission shifted fine with the occasional grind going into second. My problem was that both seals where leaking thus I decided to open her up and inspect everything while I was in there.
To this point I have used all of the previous posts(extremely help-full)!! I have both the shafts out and laying on my table. I have all of the gears etc off of the input shaft using the bang the end on the garage floor method. Here are a some cloudy pictures of my progress.
http://forums.pelicanparts.com/uploa...1206299275.jpg
http://forums.pelicanparts.com/uploa...1206299327.jpg
stacks on table...
http://forums.pelicanparts.com/uploa...1206299539.jpg
http://forums.pelicanparts.com/uploa...1206300311.jpg
I inspected the input shaft and decided for sure to replace all syncros and dog teeth. I really want to get a good look at 1/2 but I am having trouble getting the number one roller bearing on the pinion shaft to budge. I have been attempting to use the method shown in a previous post using two pieces of wood to support the shaft by the first gear. I assume you then hammer down(rubber mallet) on the top of the shaft. Will this do damage to the speedo gear? Any other methods for getting this gear off? I can't bang this on the garage floor can I? The speedo gear just looks so brittle. Also I have three 915 axles in unknown condition. Is it feasible to borrow parts I.E. sycros or sliders etc? Do I need to do it in groups as all of these parts have meshed together? Any help would be greatly appreciated.
Jim Sims 03-23-2008 12:51 PM
"Any other methods for getting this gear off?"
Use a hydraulic shop press to smoothly apply the required forces; support first gear on brass, aluminum, wood, hard plastic (ABS plastic pipe) or other soft but sufficiently strong material; press against the speedo gear through a "pad" of hard plastic.
1st and 2nd gear synchro/slider/spider parts were pretty much interchangeable through 1976; after that there were changes. 3rd through 5th and reverse parts will likely interchange from 1972 through the end of production.
RWebb 03-23-2008 12:58 PM
you might want to see if there is a way to upgrade the sealed guide tube...
