915 rebuild Questions
Well I am spending Easter morning looking over all of my 915 internals. It is a 72 with the sealed guide tube. The Transmission shifted fine with the occasional grind going into second. My problem was that both seals where leaking thus I decided to open her up and inspect everything while I was in there.
To this point I have used all of the previous posts(extremely help-full)!! I have both the shafts out and laying on my table. I have all of the gears etc off of the input shaft using the bang the end on the garage floor method. Here are a some cloudy pictures of my progress.
stacks on table...
I inspected the input shaft and decided for sure to replace all syncros and dog teeth. I really want to get a good look at 1/2 but I am having trouble getting the number one roller bearing on the pinion shaft to budge. I have been attempting to use the method shown in a previous post using two pieces of wood to support the shaft by the first gear. I assume you then hammer down(rubber mallet) on the top of the shaft. Will this do damage to the speedo gear? Any other methods for getting this gear off? I can't bang this on the garage floor can I? The speedo gear just looks so brittle. Also I have three 915 axles in unknown condition. Is it feasible to borrow parts I.E. sycros or sliders etc? Do I need to do it in groups as all of these parts have meshed together? Any help would be greatly appreciated.
1973 arctic silver widebody 3.2
1979 sc white Targa(soon to be Talbot yellow)
2002 silver Audi allroad
Old 03-23-2008, 12:26 PM
"Any other methods for getting this gear off?"
Use a hydraulic shop press to smoothly apply the required forces; support first gear on brass, aluminum, wood, hard plastic (ABS plastic pipe) or other soft but sufficiently strong material; press against the speedo gear through a "pad" of hard plastic.
1st and 2nd gear synchro/slider/spider parts were pretty much interchangeable through 1976; after that there were changes. 3rd through 5th and reverse parts will likely interchange from 1972 through the end of production.
Old 03-23-2008, 12:51 PM
AutoBahned
RWebb's Avatar
you might want to see if there is a way to upgrade the sealed guide tube...
Old 03-23-2008, 12:58 PM
