dorschman's Avatar
Garage door opener "install"
This may receive the award for the least technical post ever on the board.
Anyhow, I was viciously attacked a few days ago by my garage door opener during some spirited driving. Came out of nowhere and gave me a crushing blow to the temple. Were it not for the fact that it lacks arms, legs, a mouth, and a brain it could have killed me.
I did a little thinking today and decided that we could coexist if I could just give it a home where its' prey instinct would not be stimulated.
This is what I came up with-
I had to bend the clip with a pair of pliers to make it hold tightly. I then applied some adhesive felt to the back side of the remote so it will not rattle with bumps.
So far works fine with range similar to when it was clipped in its' predatory perch on the visor.
Easy to remove- just remove the ash tray and easy to slide out if necessary.
This is about as technical as I get. So many people have helped me on this board that I thought I would try to contribute in a small way.
erik dorsch
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 03-24-2008, 04:56 PM
Believe it or not, I really appreciate this! Mines stuck of the door panel and I never liked that. I did not want to use the sun visor, so this seems to be a good solution. Thanks
Old 03-24-2008, 05:28 PM
Paul K's Avatar
I've heard about people stealing garage door openers and getting your address from documents in the glove box- then you get home and it's too late. I think I'll try your idea with mine- always thought it looked tacky on the visor! FWIW, my Range Rover had a built-in system that would open the door from a greater distance than the standard openers- and had three channels. I thought that was a great idea- pity more manufacturers don't use it...
Cheers,
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 03-24-2008, 06:08 PM
Designer King
Paulporsche's Avatar
Thanks...think I'll rethink mine.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-24-2008, 08:02 PM
3.2 CAB's Avatar
The doors on my garage are both controlled by my key fob, plus additional lighting. This door opener key fob is smaller than most of the alarm remote fobs. One button open the front, the middle button turns on additional lighting, if desired, and the third button opens the door on the opposite end on the garage, that way I can drive through if I need to. The openers also turn their own lights on when activated. I use the key fob remote, so there is not an opener in the car, if I am not in the car.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-25-2008, 12:26 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Nice Idea! I painted my black and placed on my side pocket as not to be so obvious but under the ashtray or console is a great idea.
'85 Carrera Targa
PCA/POC
Old 03-25-2008, 12:39 AM
dorschman's Avatar
I had mine in the side pocket for a while as well. I always seemed to kick it when exiting the car.
erik
87 911 coupe "Katy"
Summer Yellow
Old 03-25-2008, 04:05 AM
Cheers,
Paul.
They pretty much all do. Even saw one one a $12k Hyundai.
But it was pretty rare back in the mid 80's.
Old 03-25-2008, 09:07 AM
Tired Member
DaddyGlenn's Avatar
I like it! I keep mine clipped to my log book in the glove compartment, easy access and out-a-sight.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 03-25-2008, 11:03 AM
911 addict
mtbguy's Avatar
Looks good.
Did you try to remove the clip and put it INSIDE the ashtray- that is what we have ended up doing on all of our cars. You can also buy a smaller Genie keyfob type that will fit for sure inside the ashtray. I put double sided foam tape on the bottom of it and place it in the ashtray- no buzzing or vibrations, and no-one sees it either.
1987 Carrera Cab
Toyota Landcruiser
500SL
Old 03-25-2008, 11:26 AM
#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
Did a similar install placing the opener under the dash with velcro. works great!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 03-25-2008, 11:34 AM
3.2 CAB's Avatar
dorschman, I must say, that I really like your "clean" looking interior.A++++!!
When I built my shop, I installed 16'x8' doors on each in. This was done if I have to bring something in on my tow-dolly, trailer, etc., or if I just wanted to use the other door. The two openers came with a $hit-load of openers. After all was done, I had 4 of the larger 3 channel openers(not really large, only about 1"Wx2-1/2"Lx1/2"thick), 4 of the 2 channel openers, the same size as the other 3 channel openers, and 4 of the key fob, 3 channel openers. I am really glad I did come out with so many openers, that way I was able to hand out openers to all of the people that might need entry to my shop. After all was said and done, I still have 4 openers in my house, that are just spares. I use the key fob openers on the different sets of keys for the cars and trucks that I drive.
Newest additions-
others...
Old 03-25-2008, 11:58 AM
