SirAndy's Avatar
Arrow early 911 ignition lock problem ...
i read every article on this planet about how to rekey your 911 ignition key, but i'm stuck ...
i can't figure out how to remove the inner cylinder with the tumblers ...
i drilled out the pin and removed the lock from the assembly, but i don't see how the lock itself would open to give me access to the tumblers?
here's what i got, the assembly is used and supposed to be from a '74 car:
HELP!
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 03-29-2008, 05:39 PM
SirAndy's Avatar
nevermind, the search finally worked ... i knew someone had to have had the same problem before ...
Ignition switch - inside to fix START lockout
Old 03-29-2008, 06:35 PM
