-   -   Installing SSI - Backdated (http://forums.pelicanparts.com/porsche-911-technical-forum/401277-installing-ssi-backdated.html)
SigmundF 03-31-2008 12:42 AM
I have bought a set og new SSI for backdating my exhaust on a 911 - 76 2.7l. I have a question regarding the left heat exchanger there is a pipe coming out near the top of the heat exchanger that I did not have on the original one. Any idea what to do with it? Shall I just leave it or plug it??
http://forums.pelicanparts.com/uploa...1206949314.jpg
fred cook 03-31-2008 04:37 AM
Extra pipe..........
I believe what you have is a set of SSIs for an engine with the mechanical fuel injection. This pipe supplies hot air to the thermostat "stack" that expands and leans the mixture as the engine warms up. Just plug or cap the extra pipe.
Good luck with your project! Watch out for rusty/stubborn exhaust stud nuts. Do a search on the BB for info on safely removing the old nuts without breaking studs.
SigmundF 03-31-2008 05:33 AM
Extra pipe....
Thanks for the quick reponse....
The old ones are already off, and no broken exhaust studs :)
