-   -   Fuse box labels (http://forums.pelicanparts.com/porsche-911-technical-forum/401726-fuse-box-labels.html)
Dougieboy1 11-23-2016 10:55 AM
As you were!!
i just clicked on the link again and it works! I must have done something wrong the first couple of times!
Excellent DIY resource!
yaya5269 11-23-2016 03:29 PM
link is working
good job !!!
thanks
pope 11-24-2016 02:23 AM
Terrific.
Let me know if you have any issues and I'll see what I can do to help.
pope 10-03-2017 05:48 AM
NEW LINK
http://pope.go.ro/FuseBoxLabels/FuseBoxLabels02.pdf
Koizumi 10-03-2017 08:51 AM
It's not working for me...
JJ 911SC 10-03-2017 08:54 AM
It work for me.
If you are at work, might be some security setting.
Hawkeye's-911T 10-03-2017 09:38 AM
No luck here either.
pope 10-14-2017 12:02 AM
Should be OK now. It was probably DNS's taking a while to sync.
echecsqueen 10-14-2017 09:13 AM
Thank you Pope. This is a great share.
Hawkeye's-911T 10-14-2017 10:35 AM
Got it! Thanks Pope
Cheers
JB
pope 10-14-2017 01:36 PM
Was in a drawing mood tonight so added an attempt at E Sully's 73 in case he or anyone else needs it.
http://pope.go.ro/FuseBoxLabels/FuseBoxLabels03.pdf
Vintage56 03-19-2018 04:00 AM
Fuse Box Labels
Hi, All
Looking for the template for 1973 911. Here's what I have from fuse boxes:
Fuses on 1973.5 911
Top Fuse Box
Fuse (amp) Circuit
1 5 – Yellow luggage/glove box light, interior light, clock
2 16 - Red warning light
3 25 - Blue window opener
4 16 – Red cigarette lighter (aux. heater)
5 16 - Red sunroof, (rear window wiper)
6 25 - Blue windshield wipers, windshield washer motor
7 25 - Blue fresh air blower, rear window defroster
8 16 - Red stop, turn signal & backup light
9 5 – Yellow front L. blinker light
10 5 – Yellow front R. blinker light
Bottom Fuse Box
Fuse (amp) Circuit
1 8 L. high beam
2 8 R. high beam
3 8 L. low beam
4 8 R. low beam
5 5 – Yellow L. parking light
6 5 – Yellow R. parking light
7 5 - Yellow license plate light
8 16 - Red (fog light)
Rear Fuse Panel
Fuse (amp) Circuit
1 5 - Yellow
2 8 Ignition box
3 25 - Blue
8 amp fuses are white
And a photo:
http://forums.pelicanparts.com/uploa...1521457153.jpg
Thanks for the great effort!
pope 03-19-2018 07:08 AM
Maybe you can get a higher resolution picture of the 10 fuse label? Some of the text is illegible.
The second one is the same as the 1970-72.
Vintage56 03-26-2018 05:40 AM
Fuse Box for 1973 911E
My fuse box matches Page 4 on the attached link that you have just recently provided, with one change: the #4 fuse (windshield wiper) is in the #6 fuse (cigarette lighter) position and visa versa. In other words, all is the same except fuse #4 is in the #6 position and #6 is in the #4 position. The other 8 fuses, per the diagram on Page 6, are exactly the same.
Does this help? The car is a 1973 911E.
Thanks very much SmileWavy
pope 03-26-2018 11:13 PM
Actually, fuse 7 is also different and fuse 1 which is probably the same electrically, is described differently.
So my problem in completing this correctly is that I can't read the German and French for fuses 1 and 7.
JJ 911SC 03-27-2018 02:40 AM
I though they were labeled Trilingual's
Deutsche
English
Français
Vintage56 03-27-2018 03:54 AM
Yes, you're correct. They are in 3 languages. I will try to get the details in French and German today. English is easy!
Vintage56 03-27-2018 06:29 AM
Pope
Here's what I can read from the cover:
#1
Innen-Kofferraum- Hand-
schuhkastenleuchte, Zeituhr
luggage/ glove-box-light
interier light, clock
ecl. linter. / coffre a bag. /
boite a gants montre
#7
Frischluftgeblase
Helais Heckheizscheibe
fresh air blower
rel. -heated rear window
soufflerie ar frais
rel -lunette ar. -chauf.
Vintage56 03-27-2018 06:30 AM
Thanks Pope for your assistance with this...It is the best I can read it given age and wear.
Thanks again
pope 03-27-2018 07:32 AM
Yeah, I think that's good enough.
Have a look here:
http://pope.go.ro/FuseBoxLabels/FuseBoxLabels04.pdf
Let me know if it's OK and if you need anything else.
pope 03-27-2018 07:35 AM
Hahaha.
Looking for a solution for the 1973.5 I stumbled across someone that has actually monetized my work!
https://www.kroonwireharnesses.com/index.php?route=product/search&search=label
He's actually watermarked it with 'SAMPLE'. So no one steals it ;)
So if anyone can't be bothered in printing, cutting, gluing etc. they can get it for just 5 EUR! :D:D:D
Vintage56 03-27-2018 07:49 AM
Thanks so much...
geoff_68s 10-06-2018 11:30 AM
Pope, if you're interested in adding a trilingual label for an early 12-fuse box, here's one from a '66, which also works on my '68, and, presumably, other SWB cars:
http://forums.pelicanparts.com/uploa...1538850403.jpg
Some of it isn't super legible in the photo, but it was the best I could get, so I can transcribe it for you if you want.
-- Geoff
pope 10-11-2018 11:45 PM
Thanks for adding one more version to the list!
I'm a bit busy these days with other stuff. I'll get on it as soon as I free up some time.
techweenie 02-20-2019 09:03 AM
Have a look here:
It looks like you've done exactly what I need. (a 10-fuse box label for a 70 911) but I cannot get your link to open for me. Cant get to your server at all.
Is there a new link? Or can I host your PDFs for you?
pope 02-25-2019 01:35 AM
Should be working now.
pocketscience 11-26-2019 04:06 PM
Link just seems to time out after ages... is there an updated one?
pope 11-28-2019 01:41 AM
I can't find an issue, should be OK. Want to try it again?
runner4fun 12-25-2021 04:28 PM
Would someone please re-post the link to the fuse box labels? It is not working again. Thank you
pope 12-26-2021 01:37 PM
Let's try this dropbox link:
https://www.dropbox.com/s/uwkni3v1sewcxkk/FuseBoxLabels04.pdf?dl=0
runner4fun 12-26-2021 01:55 PM
Great. Thanks very much.
fastricky 04-12-2022 11:59 AM
Thank you!
The Dude 12-28-2023 02:34 PM
link in msg #70 still works CAO 28 Dec 2023
kevstens 01-19-2024 08:22 PM
Fuse box paper tags
Is it possible to get a copy of the fuse tags for the two front 8 fuse boxes for my 69 911E? Thanks, Kevin
