1-6-2-4-3-5-1-6-2-4-3-...
Fuse box labels
Horrible isn't it?
![]() To fix it, download this pdf file [edit]version 02[/edit] and print out the ones you like. Make sure you do not scale the printout down or up. It should be 100% zoom in the print settings of your pdf viewer. The fuse order is for my 1970 911E and I know it's good for other years but certainly not all. I have two versions for each of the three fuse boxes in the car. One version is the original and the other is modified in some way: On the fore labels I've added fuse size in amps and the aft one I've switched the order because the fuses are upside down on my car (don't know if this is standard). Now, cut around the printouts crudely with scissors. ![]() Take a see-through sticker (you can probably get this at a bookstore to protect book covers) and carefully stick the printout face down. ![]() Cut a large enough piece of the sticker so you can cover the back as well. Don't mind about the sides or top, just make sure the sticker is smooth on the face of the printout and on its back. You should end up with something like this: ![]() Use a razor to cut off the edges: ![]() Cut a cross in the middle of each of the two circles in the fore fuse box stickers: ![]() And you're ready! ![]() I can add other versions of fuse boxes to the pdf file but I'll need details about them.
'70 911E Coupe, Webers 40IDA Last edited by pope; 04-04-2008 at 12:57 AM.. Reason: Updated PDF file to include 1972 10-fuse box |
Nice job!
Another great Pelican DIYer.
Silver 1980SC Euro coupe |
19 years and 17k posts...
Thank you!!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Thanks. And since I have a 70E as well it will be perfect.
1989 Cabriolet 1970 911E Sold |
Thanks! Posted a link at the Sreg. forum.
John
997 C2S 2005 "Slate grey"(special order 1965color) 911 SC 1978 Silver/black 34.000 miles from new! 911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black |
Great! I have been missing two of these for a long time....I can't get the link to work but I'll keep trying.
-Jess |
You probably have port 8080 blocked.
I can do nothing about that unfortunately. If someone else can get it on their server, or our host has a spot where we can upload it, that would be helpful.
'70 911E Coupe, Webers 40IDA |
THANKS! Just about finished with my 70T and these are just what I need.
I still have the originals but they look just like yours. Don't know what I'd do without this forum. Thanks again. Gary
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
72 T
Just finished mine a didnt have these.
Thanks!!!!
_____________________ Mark 911 T 1972 Black almost done! |
nice work.
but FYI, slight difference on my 72. MARK, heads up! 3 and 6 are exchanged for each other on the big box- go figure! POPE, would it be an easy swap? plan on using the rear fuse label tho. thanks for the time and effort. another example of why this site is great
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" Last edited by robmog; 04-03-2008 at 06:35 PM.. Reason: addition |
I uploaded a version that includes the 1972 modification you asked for Bob.
Its size should be fine although it's probably only a near-perfect replication of the original (as opposed to the perfect one for 1970). Did 70 and 71 have the same fuse boxes? Did 72 and 73? Anyone know?
Robert Williams 70' 911T |
Email sent with the fusebox pdf file.
John
Sorry dear friends, server maintenance killed the link.
It's up again and should be working fine.
'89 930
Pope - the link seems to be gone again. Can you repost or email to me ??
Thanks, 1topcat@comcast.net
'89 930 3.4, twin plug, crank fire, K27, cams, B&B I/C, coil overs, EVO '73 911 'ol Yeller - 3.0 ST Clone '74 911 green with NV - 3.6 RSR to be '87 951 Red Vitesse Stage 3r, AOR, Ruf, Motion Control '01 996 ECU flash, 911Tuning exhaust, DV, Techart |
Pope great job but link is down. Could you email one more out for a 72??
Thanks, I was just looking for these to id my correct fuse sizes. Girt ![]() girt1@verizon.net |
French Import
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Way to go Zippy!
![]() I put these on the server when its status was much more stable. I should look for another server to put them on now...
"To fix it, download this pdf file [edit]version 02[/edit] and print out the ones you like. Make sure you do not scale the printout down or up. It should be 100% zoom in the print settings of your pdf viewer."
Great tip, unfortunately the PDF link seems to be broken. |
I'm trying to edit the link in my post above to fix it but I can't :/
Zippy posted the fixed link above: NEW LINK: FuseBoxLabels02.pdf
| Tags |
| fuse box label |
