| vreference |
04-03-2008 08:09 PM |
Ambient Temperature & Valve Lash
I am currently in the midst of setting the valve lash in my unknown mileage 3.2L in an unheated garage. It's about 50 Degrees out here and will be for a few days. Using the "back side" method I've found a couple valves that are less than .0025 and I'm just wondering if setting the lash nearly 20 degrees less than the recommended 69 degrees is going to cause problems for me?
On a positive note I put an allen wrench on all lower head studs and all appear to be intact! I was happy.
