-   -   5 Amp fuse. Where do I get one? (http://forums.pelicanparts.com/porsche-911-technical-forum/40222-5-amp-fuse-where-do-i-get-one.html)
John W. 02-08-2012 08:30 PM
I just checked. Pelican carries 5 amp fuses now.
wallstreet 02-08-2012 09:36 PM
Ceramic or glass.
Joe Bob 02-09-2012 06:26 AM
11 year old thread? Oiiiphffff.....
wallstreet 02-09-2012 08:24 AM
OK so you bought your last part 11 years ago. What does that have to do w/ buying a non-ceramic fuse that is difficult to find for someone else's 911 or 928? Ommphphffff !:confused:
Seriously, anyone looking to gain an edge on maintenance of an electrical system might consider a glass type fuse. I realize this person or even you are not interested but others might. This thread was merely an entry to remedy a problem many Porche/VW/Volvo/BMW owners have for more than 11 years. I looked for glass fuses for several months to replace corroded ceramic fuses. Once the new fuses were installed, my time consuming maintenance cleanup was a minimum. I was just passing on a small piece of information to anyone interested.
Sorry if you were offended.
Joe Bob 02-09-2012 08:33 AM
You're missing my point....the OP and follow ups would have asked more questions if they couldn't find what they needed.
The OP isn't even a registered user, will not get a response nor will anyone benefit from a crusty old thread.....but hey, have at it.....
wallstreet 02-09-2012 09:02 AM
You're missing my point. I was not specifically addressing OP. I was not even expecting a response... from anyone. The fact that no one asked does not mean more information is added.
As stated, I was passing on some information others might be interested in regarding either 5 amp GLASS fuses or glass fuses in general. It obviously is not of interest to you except to make a off handed opinion. Your opinion is understood. If the fuse issue does not apply to you then use the delete key. Many owners have had a corrosion issue and maybe never knew a replacement was available.
"but hey have at it"
hbueno 02-09-2012 11:00 AM
I don't mind the old thread resurrection.
I've been on the prowl for glass GBC fuses myself. NAPA Online shows them as being in stock, but I haven't tried ordering to see if they will send glass or plain old plastic or ceramic fuses. I never thought of checking on ebay.
wallstreet 02-09-2012 11:35 AM
Thank you
This could be a source:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
I paid dearly for mine as I had experience from the Volvo several years ago. I called the Volvo dealership and they said "nothing like glass fuses exist". Altho I purchased from them years earlier.
I also checked NAPA, OReilly's and others. They showed an SKU but zero inventory.
Hope this helps.
hbueno 02-10-2012 05:01 AM
Last night I found a vendor on eBay who had four packages of Bussman glass fuse assortments. I pulled the trigger and bought them for just under $20 total including shipping.
wallstreet 02-10-2012 06:40 AM
Great... then resurrection IS good.
