Eletrical problem
I have a 72 911 Targa. Just recently my rear lights went out(brake and driving) and so did the blinkers. I checked the back fuses all are good. I am checking the bulbs but it would be really wierd if all went out at same time, any Ideas. Where else can i look
make sure all the wires are still on the light switch. then check the fuse box for loose connections or corrosion.
Bet you lost the ground cicuit for the rear lamps-check the brown wires at the stud inside the engine compartment.
------------------ Clay McGuill '66 912, '97 Jeep Cherokee www.geocities.com/the912guy |
| All times are GMT -8. The time now is 07:46 AM. |
