Targa King
Guest
Posts: n/a
Post Eletrical problem
I have a 72 911 Targa. Just recently my rear lights went out(brake and driving) and so did the blinkers. I checked the back fuses all are good. I am checking the bulbs but it would be really wierd if all went out at same time, any Ideas. Where else can i look
Old 05-11-2001, 05:36 PM
john walker's workshop
Guest
Posts: n/a
Post
make sure all the wires are still on the light switch. then check the fuse box for loose connections or corrosion.
Old 05-11-2001, 06:19 PM
ClayMcguill
Guest
Posts: n/a
Post
Bet you lost the ground cicuit for the rear lamps-check the brown wires at the stud inside the engine compartment.
Clay McGuill '66 912, '97 Jeep Cherokee www.geocities.com/the912guy
Old 05-11-2001, 06:35 PM
