-   -   2-3 second delay on start-up. (http://forums.pelicanparts.com/porsche-911-technical-forum/402702-2-3-second-delay-start-up.html)
m_wuebben 04-08-2008 08:34 AM
:confused:When I turn the key on my '81 SC, the fuel pump starts up and the dash flashes like normal, but the engine does not start to turn over for 2 to 3 seconds. This doesn't seem normal. Could it be a low batterey charge?? Cheers, Mike
m_wuebben 04-09-2008 10:17 AM
any ideas??
lv600 04-09-2008 10:27 AM
I had the same issues with my 78 SC. It was a sign that the starter was going out. I replaced the battery and checked the grounds, etc. The starter finally wouldn't engage or crank, just click. Changed the started to a hi-torque model and never had another starter/hesitation issue. Cranks right away!
Gunter 04-09-2008 11:11 AM
+1
Check all wires and battery terminal for corrosion; open the connections and use dielectric grease.
Check all ground connections, especially where the neg cable connects to the body. (It's hidden out of sight)
m_wuebben 04-10-2008 05:46 AM
Thanks. The car's up in the air right now for a steering rack freshen, so I might as well do it now. Cheers, Mike.
