m_wuebben's Avatar
2-3 second delay on start-up.
When I turn the key on my '81 SC, the fuel pump starts up and the dash flashes like normal, but the engine does not start to turn over for 2 to 3 seconds. This doesn't seem normal. Could it be a low batterey charge?? Cheers, Mike
1981 911 SC Black / Black & Tan sunroof coupe.
Run like the wind...straining the limits of machine and man... (Peart)
Old 04-08-2008, 08:34 AM
m_wuebben's Avatar
any ideas??
Old 04-09-2008, 10:17 AM
I had the same issues with my 78 SC. It was a sign that the starter was going out. I replaced the battery and checked the grounds, etc. The starter finally wouldn't engage or crank, just click. Changed the started to a hi-torque model and never had another starter/hesitation issue. Cranks right away!
-Jon
78 911SC Coupe
Old 04-09-2008, 10:27 AM
Somatic Negative Optimist
Gunter's Avatar
Check all wires and battery terminal for corrosion; open the connections and use dielectric grease.
Check all ground connections, especially where the neg cable connects to the body. (It's hidden out of sight)
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-09-2008, 11:11 AM
m_wuebben's Avatar
Thanks. The car's up in the air right now for a steering rack freshen, so I might as well do it now. Cheers, Mike.
Old 04-10-2008, 05:46 AM
