ohecht
Guest
Posts: n/a
Post Specs for testing clutch switch out of car?
I am troubleshooting the CC clutch switch on my 82. All I get is continuity when the lever is closed (=clutch pedal forward, and the switch is open when the lever is pressed (=clutch pedal up)
Is it a simple open/closed switch?
The reason the switch is suspect is because the Ohm reading between ground and pin 3 from the amplifier connector was out of spec.
Thanks,
Olivier
82 SC
Old 05-13-2001, 07:18 AM
john walker's workshop
Guest
Posts: n/a
Post
it's a simple on/off switch. use an ohmmeter.
Old 05-13-2001, 09:26 AM
