Guest
Posts: n/a
I am troubleshooting the CC clutch switch on my 82. All I get is continuity when the lever is closed (=clutch pedal forward, and the switch is open when the lever is pressed (=clutch pedal up)
Is it a simple open/closed switch? The reason the switch is suspect is because the Ohm reading between ground and pin 3 from the amplifier connector was out of spec. Thanks, Olivier 82 SC |
Guest
Posts: n/a
it's a simple on/off switch. use an ohmmeter.
