-   -   Help me name a part/piece for a 911SC...please (http://forums.pelicanparts.com/porsche-911-technical-forum/403402-help-me-name-part-piece-911sc-please.html)
germaniac 04-11-2008 09:42 PM
Guys,
I just replaced my rubber door seals but what is that material (cloth?) strip called thats screwed to the upper inside of the doors? Does pelican have a part number?
Thx,
Rob
Cooper911SC 04-11-2008 10:18 PM
Hi Rob- I think you are talking about the fuzzy seal. It is held in with clips. The part # is 901 531 935 20 I tink Pelican has it for about $19.
Hope this helps.
Cooper
germaniac 04-12-2008 08:02 AM
Cooper,
I removed the piece today; I will post a pic later; I do know of the piece you are talking about...but my bad...it isn't a fabric or cloth etc. It is a pliable piece that starts inside body where the door meets, right where the rear view mirrors begin. It is screwed to the body with about 8 philips head screws..
any help on where I can get a pair of these would be appreciated
DavErb 04-12-2008 09:02 AM
Looking at my parts list here. Could it be the sealing rail? Its a strip with a sort of V shaped cross section that attaches to the door opening and runs from about the same level as the fender line to the back upper corner of the door opening. Held in with several tapping screws. It looks like its there to supplement the door seal in excluding water and wind. If thats the case the part #'s for the coupe are 911 542 403 01 for left one and 911 542 404 01 for the right one
germaniac 04-12-2008 10:31 AM
That might be it...everything sounds right except for the v-shaped cross section...is there anywhere to see a pic?
Thanks for your help
DavErb 04-12-2008 11:04 AM
just did a search on that part # with our host and its called an Upper Velvet Door seal here. Located in the Rear and Side Door seals section. There a pretty nondescript photo
germaniac 04-12-2008 03:17 PM
Thanks for the help guys!
