Help needed on 1977 911S
Picked up a 77 911 not running missing some ign parts. I have a 3 pin perma tune and bought a new perma tune coil (had no coil). Installed new points and want to set the dwell. I am confused on how to hook up my dwell meter to do this! Pleas advise!
Old 04-10-2008, 03:43 PM
Designer King
Paulporsche's Avatar
I may be able to get a diagram for you later today. In the meantime here's a bump for you so someone else may be able to help sooner.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-11-2008, 08:01 AM
al lkosmal's Avatar
John,
Per Waynes book "101 Projects for your Porsche 911".
"hook the signal wire of the dwell meter directly to the points wire that is coming off the distributor. In some cases it may be easier to attach the dwell meter to a long screwdriver and place the tip of the screwdriver on the contacts where the wire is plugged into the distributor."
good luck
al
RGruppe #669
http://www.x-faktory.com/
Old 04-11-2008, 08:21 AM
Dan in Pasadena's Avatar
I have always used the distributor side of the coil and ground. Works for me. Best.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 04-11-2008, 08:33 AM
Al
Thanks I have the book, but I don't understand the hookup. I hook up meter black to ground and red to wire at dist. using a screwdriver from dist to wire so I can clamp on to that, Is that correct?
John
Old 04-11-2008, 12:47 PM
I never figured it out, which is why I now have a Pertronix Ignitor kit in it.
Old 04-11-2008, 12:51 PM
HarryD's Avatar
Originally Posted by John Pedersen View Post
Al
John
That is pretty much it.
Be aware that the points for a CDI system are just to switch the CDI Box on and off. As long as they are switching, the amount of thime closed vs open does not really matter much.
You can use a feeler gauge to set the points gap and, usually, you will be close enough.
To use a feeler gauge, bump the engine until you get the points open (rubbing block on a high point of the distributor lobe). Loosen the adjusting screw and slip your feeler gauge between the points. Without forcing the points block, move it until the point close on the feeler gauge. Tighten the screw. Be sure to put a dab of distributor grease on the lobe to help the points last longer. If you did this correctly, you are good to go.
Also, check your timing at 6000 rpm.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-11-2008, 01:12 PM
New problem! No spark, possibly the Prematune is bad, not letting power to the dist. so i would get a reading on dwell meter. Also, ordered a Bosch CDI.
John
Old 04-11-2008, 01:16 PM
HarryD's Avatar
John
John,
You can check for this. Do a search for "telegraph test" and user "early_s_man". He outlines a procedure to allow you to determine if the CDI is bad.
Harry
2020 MB E350 4Matic
Old 04-11-2008, 01:41 PM
76911's Avatar
Can you hear a noise comming out of the CDI box? buzzing or high pitch wine
Denny
1976 911s targa
1974 widebody G2 style GroupeB 76
www.G2Performanceshop.com
Cylinder head recon, case savers,twin plug,rocker arms
Old 04-11-2008, 01:59 PM
I believe Permatune is bad! And if it is would I not get a reading on my dwell meter????
Old 04-11-2008, 02:13 PM
HarryD's Avatar
FWIW, Permatune do not make any noises. This check is only good for the Bosch CDI's.
Harry
2020 MB E350 4Matic
Old 04-11-2008, 08:09 PM
HarryD's Avatar
Just to be sure. Did you check the middle teminal on the harness to the Permatune to verify that you had power (12v) when the key is in the run position?
Harry
2020 MB E350 4Matic
Old 04-11-2008, 08:13 PM
HarryD's Avatar
Hi John, you should also check that the points are giving the CDI a good signal by attaching an ohmmeter to Pin C of the connector and crank the engine to see the circuit make and break.
From the Permatune Site:
A = + or 15, coil hot primary terminal ( - or 1, coil ground primary terminal is connected to the engine ground).
B = Power from ignition switch.
C = Distributor breaker points.
D = Ground
Harry
2020 MB E350 4Matic
Old 04-11-2008, 10:37 PM
pozee's Avatar
John,
To set the dwell (using a meter) the car has to be running.
I'm not clear on whether you got yours running.
If not, you need to set the initial point gap - then get it going - then test the dwell to bring it within spec's. The larger the gap, the lesser the dwell.
Hope this helps.
pozee
Old 04-12-2008, 06:33 AM
