Help - relocating on-engine cooler
I'm in the process of redoing the oil cooling on my 914 3.2 conversion. I'd like to remove the on-engine cooler and replace it with a larger after-market unit. I've seen a plate which bolts in this location and provides two AN-16 (or similar) fittings to run hoses to the new cooler, but I cannot for the life of me find it now. Smart racing comes the closest with a kit to relocate the oil filter to this area, I could then run a more standard oil filter relocation kit from there but the correct plate would be a much nicer solution.
I really need to get this peice in a hurry and will be extremely grateful for any help. Thank you!
Old 04-12-2008, 11:45 AM
