-   -   Window net installation (http://forums.pelicanparts.com/porsche-911-technical-forum/403632-window-net-installation.html)
chriswening 04-13-2008 09:33 AM
Need the benefit of other's experience.
Nearly finished building my RSR clone racer and am confounded by how to attach the lower part of the window net to the roll cage. Bottom of net to roll cage is 5.75 inches.
Any suggestions or photos?
Chris
http://forums.pelicanparts.com/uploa...1208104338.jpg
chris57 04-13-2008 10:06 AM
On my previous race car I used small plastic covered cable (1/8th inch I believe) I bought it by the foot at the local hardware store. They sell the aluminum crimps to permanently attach cable. One end around the roll cage and one through a hole in that aluminum strip on your window net.
peehonix 04-13-2008 10:15 AM
Window Net Options
I did this install on my two RSR's. Here are two options for you to consider.
You could also not weld a tab to the car and just wrap the cable around the cage.
http://forums.pelicanparts.com/uploa...1208106662.jpg
http://forums.pelicanparts.com/uploa...1208106701.jpg
http://forums.pelicanparts.com/uploa...1208106742.jpg
http://forums.pelicanparts.com/uploa...1208106780.jpg
chriswening 04-13-2008 10:37 AM
Cable idea is simple and easy. Will head to ACE and do that that afternoon.
Thanks for the help guys.
Chris
