Piston Ring Rotation
I've been doing some reading out of curiousity about piston ring rotation, and I think it's an accepted fact that rings rotate and are encouraged to do so. This NASA study (albeit an old one) estimated that ring rotation is on the order of 1 RPM per 1,000 engine RPMs.
Total Seal on it Web site says that cylinder cross-hatching determines ring rotation speed: "Cross-hatch angles can also vary depending on the application. These angles determine the critical ring rotation speed, generally a 45° cross-hatch angle will do a very good job." Anyway, when I disassembled my 3.0 engine, the rings were all over the place. Given that rings rotate, why do we worry so much about staggering the ring end gaps when replacing rings? It seems to me that we're ensuring the best possible conditions at start-up, but beyond that do we have any control over where the gaps may end up at any point in the start/shutdown/start engine cycle of life? Brian
'82 SC Targa '83 SC Cabriolet |
good question - subscribed
+1 on good question...
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
abit off center
If I remember correct GM had a recall on may engines because someone on the line installed the rings with all the gaps lined up, didn't work very well and will not correct its self.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I heard of someone doing that on a Lycoming engine. The plane ran out of oil on the run up.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Maybe the orientation is most critical at break in and then, when they are broken in and moving all over the place on their own, it's not an issue? I plan to stagger mine according to the book when I put everything back together, just to be safe.
I staggered mine, too, but I imagine they won't stay put for long. Maybe, as you say, it's critical to stagger rings for that first start-up and break-in. The rings definitely move around, because otherwise we would see specific cylinder wear issues, right?
Brian
But what do I know. I'm an armchair quarterback. I did have a friend who rebuilt the engine on his Triumph motorcycle with the rings all lined up, and it used a lot of oil. he drove it about a thousand miles before tearing it down. The problem did start to rectify itself, but only partly. I will be interested to see what the real deal is. |
THE IRONMAN
You got it...The break in is critical, so better to give him all the help it deserve.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
