Follow me
seymore's Avatar
Large bolt on shifter base
I'm in the process of putting in a short shift kit and I'm having trouble removing the large hex bolt in the shifter housing. has anyone had this problem and how did you solve it. am I turning it the wrong way or is there a trick. Thanks
Old 04-16-2008, 01:02 PM
Try not to strip this hex bolt. It is a standard counter-clockwise turn to get it loose. I stripped mine and had to take a dremel cutting tool to cut a slot in it.
Got lucky and it came out with a straighbladed screwdriver. I then went and bought a replacement hex bolt. Try some PB blaster on it also
good luck,
Bill
Old 04-16-2008, 01:14 PM
Follow me
seymore's Avatar
BILL, I just went ahead and cut a slot in to it and presto off it came! I had pertty much stripped it anyway. Thanks a Million Jake
Old 04-16-2008, 01:22 PM
You might be referring to the large set screw and jam nut at the front of '77-on shift housings. Other than the housing mounting bolts, there are no other large bolts on a factory shift housing. I suppose if these two parts co-mingled molecules due to corrosion, it could then be considered a bolt. The set screw should have an internal hex on the end.
For non-corroded parts; to remove the jam nut, reinstall the shift housing on the tunnel. This method anchors the housing without having to build a holding jig on the bench. A vise will leave DIY scars in the aluminum housing. Use a 1/2" dr. flex handle and a 6-socket to loosen the nut. Orient the handle to push downward to loosen it (handle is on the passenger side).
What did you use to replace the large "bolt"?
Sherwood
Old 04-16-2008, 02:47 PM
