901 trans questions
These are the numbers from this trans. What is it? What would it be good for? 901/07 7192442
Old 04-22-2008, 08:30 AM
Zeke's Avatar
A 901/07 is an E and S tranny fitted to US delivery cars in '69.
correction: Fitted to NON US cars. It has the same gear ratios as a 901/13 which was for the US 911S, but the 901/07 is a die cast housing as opposed to the pressure cast /13 I wonder if a back up light is on both?
Old 04-22-2008, 08:50 AM
Grady Clay's Avatar
Milt is correct. This is a ‘normal’ 911 from early 1969. It has the die cast aluminum transmission housings but uses the 108 mm CV joints.
This was the optional 5-speed in the early ’69 911T
I don’t think there was any distinction between USA and RoW delivery.
Sometine in early spring ’69 the standard optional 5-speed was changed to the magnesium casting 901/13.
The 901/07 is geared: AFMSZ with a 7:31 R&P.
Yours is #2442 out of a total of 2529.
This should have the ‘reinforced’ input shaft
Unless updated, it will have the ‘simplified’ differential. This absolutely needs updating.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 04-22-2008, 01:02 PM
